Hillbilly Track Saw
Forum topic by SeaWitch posted 11-10-2011 03:23 AM 7652 views 2 times favorited 7 replies Add to Favorites Watch
View SeaWitch's profile
SeaWitch
149 posts in 2632 days
11-10-2011 03:23 AM
I have lots of ply to cut up. I’m too lazy to cut plywood 1st with the CS and 2nd with a TS for accuracy, and too cheap to buy a good tracksaw. So I made a 10’ track for my CS. Husband got me some aluminum strips from his old business partner, and I mounted them on some plywood and some 1 X 4’s underneath. The whole contraption is fastened on each end. I still have to tidy it up a bit, but it works perfectly!
-- When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it.”   Theodore Roosevelt
7 replies so far
View NBeener's profile
NBeener
4816 posts in 3412 days
#1 posted 11-10-2011 03:27 AM
If it works, then … it works !
As long as I clamp my clamp-on straight edge(s) FIRMLY, using c-clamps, in addition TO their built-in clamps, I get a good, straight edge and a clean cut.
-- -- Neil
View sras's profile
sras
4969 posts in 3367 days
#2 posted 11-10-2011 04:16 AM
Looks like you will be making some sawdust! Nice setup.
SeaWitch
#3 posted 11-10-2011 06:32 PM
NBeener, I can get a good edge like that too, but it’s too nerve-wracking for me. I have so much to cut up, I prefer the no-fail method. You’re tougher than I am. ;o)
Thanks sras!
View Bertha's profile
Bertha
13551 posts in 2931 days
#4 posted 11-10-2011 06:43 PM
Long live hillbilly methods!!!
View PurpLev's profile
PurpLev
8548 posts in 3886 days
#5 posted 11-10-2011 06:44 PM
thats a great setting, looks on the heavy side but that can be a good thing as it won’t be moving around too much and I like the fact it has a ply base on both sides of the blade – helps with chipout… very cool!
View JimAspin2's profile
JimAspin2
7 posts in 2756 days
#6 posted 11-04-2013 07:41 PM
How do you keep the two sides at the exact blade width apart on the cut set up?
View Grandpa's profile
Grandpa
3261 posts in 2913 days
#7 posted 11-04-2013 08:53 PM
Jim I believe there are some wood strips that connect the 2 halves. Look closely at the end and you might be able to see the strips on the bottom side. After you put these in place you can’t cut them.
