Tips & Tricks: Sharpening Tools
Forum topic by MsDebbieP posted 11-10-2011 01:25 AM 84090 views 3 times favorited 20 replies Add to Favorites Watch
18618 posts in 4401 days
11-10-2011 01:25 AM
Topic tags/keywords: sharpening tips tricks
What are your tips/tricks re: Sharpening Tools?
- what needs to be sharpened? – what tools do you use to sharpen? – sharpening processes?
(also add links to helpful blogs etc that are related to the topic)
Gateway to all Tips & Tricks Topics
-- ~ Debbie, Canada (https://www.facebook.com/DebbiePribele, Young Living Wellness )
20 replies so far
View Gene Howe's profile
Gene Howe
11167 posts in 3669 days
#1 posted 11-10-2011 01:31 AM
For chisels and plane irons I use glass, wet/dry paper, and a final hone with an Arkansas stone.
I use this doo hicky….
I’m still trying to get a decent curl on my scrapers.
View chrisstef's profile
chrisstef
17803 posts in 3247 days
#2 posted 11-10-2011 02:05 AM
Im a scary sharp kinda guy. I use it to sharpen plane irons and chisels. Grits from 220 up to 2000 glue to a flat piece of safety glass. Its sharp when it can shave a nice patch of hair off my arm.
Gene Howe
#3 posted 11-10-2011 03:36 PM
A suggestion, Chris. If you use wet/dry paper from auto paint stores, a puddle of water on the glass will hold the paper to the glass without movement.
I only have one piece of glass and just keep changing the papers as needed.
View mpounders's profile
mpounders
907 posts in 3136 days
#4 posted 11-10-2011 05:53 PM
I use the scary sharp method some, but mostly I buff and hone my carving tools using a power strop that I built. I plan to rebuild it to the full size style of the Burke Sharpening system shown below. I have used one of these at a carving seminar and really like it. It has sandpaper on two wheels for reshaping profiles on gouges and removing heavy nicks. Then it has a leather wheel and a buffing wheel for honing and polishing. I’ve stopped looking for ways to sharpen after using this—completely satisfied with my results.
I also have a shop-built version of the Wolverine style jig for my lathe tools and I like how that works also. I don’t really use or sharpen my planes much.
-- Mike P., Arkansas, http://mikepounders.weebly.com
View CampD's profile
CampD
1742 posts in 3727 days
#5 posted 11-10-2011 06:10 PM
I also use the scary sharp method, but instead of a piece of glass I use a cut-off from Granite counter-top.
The piece I have is 12×16”x 2” thk. It stays solid to the bench with-out any hold down and like glass just a little water holds the paper to it like glue. I’ve installed a lot of kitchens over the years and have a good relationship
with the granite guy. If there is one in your area they always have tons of cut-offs laying around.
-- Doug...
View Bertha's profile
Bertha
13551 posts in 2934 days
#6 posted 11-10-2011 06:22 PM
Oooh, good thread. I hope there are lots of links, because there are some top notch sharpeners here. I’m a little of everything above. I’ve got the wet wheel, water stones, scary sharp, and a bunch of jigs.
For plane irons: The Christef method for sure. I like marble windowsill from Lowe’s for my base and use the “good’ 3M adhesive spray; the adhesive comes off with acetone easily. They accept the rectangular sheets perfectly and I like to keep several set up. I’ve got a few that I clad in wood b/c I keep breaking them. My RAS table is just too attractive a place to set them, lol;)
For chisels: As above; I use a cheap Eclipse jig with a setup block.
For lathe tools: The wet wheel and powered strop. I wish I’d gone Wolverine instead of the fancy Tormek/JET.
Future: I’m working on one of those stone/strop arrays like Mike likes (above). I tried to use a foot operated treadle for the purpose but I abandoned it. I’ve got a 1hp motor that I’m planning to use.
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3356 days
#7 posted 11-10-2011 06:52 PM
the Veritas jig MkII
starting with vet and dry sandpaper for the lower grits or a diamondstone
switching to Japanese waterstones from 400grit and goes up to 8000 grit gives a mirror-polish and sharp irons
you can get 10 , 12k, 16k and 30k grit waterstones if the pocket is full of gold you don´t
know what to do with .... :-)
some stones don´t gives the morriorpolish
some waterstones don´t gives much responded to the user and others does it a long way up in the grits
depending of the brands on the stones …. people have to try different stones to find the set
that fits them and the way they use them
Dennis
404 - Not Found
2544 posts in 3210 days
#8 posted 11-12-2011 03:36 AM
I’m leaning towards p2000 wet or dry and a figure of 8 for the hone, belt sander/diamond whetstone for a regrind. (Keep quenching the steel if you’re using the belt sander) strop on a bit of mdf.
View Roz's profile
Roz
1707 posts in 4027 days
#9 posted 11-23-2011 05:30 AM
I am so far behind I’ll have to read this again. When I sharpen my tools I think they get duller.
-- Terry Roswell, L.A. (Lower Alabama) "Life is what happens to you when you are making other plans."
View RGtools's profile
RGtools
3372 posts in 2895 days
#10 posted 11-23-2011 04:38 PM
A hollow grind is about the best jig out there for sharpening. It makes free hand faster and easier than anything else.
-- Make furniture that lasts as long as the tree - Ryan
View SnowyRiver's profile
SnowyRiver
51457 posts in 3721 days
#11 posted 11-23-2011 09:12 PM
I take the tools to a sharpening service. Not that I want to spend the money, but I am lousy at sharpening stuff…I can never seem to get a good edge on it. I am taking lessons from all of your posts!!
-- Wayne - Plymouth MN
View OSU55's profile
OSU55
2033 posts in 2230 days
#12 posted 02-13-2014 03:52 PM
Sharpening, mainly plane blades & chisels http://lumberjocks.com/OSU55/blog/39391
View Kelly's profile
Kelly
2189 posts in 3185 days
#13 posted 01-12-2019 04:58 AM
I find the whole “Scary Sharp” thing kind of comical. LONG before it was a thing, it’s what I did to sharpen things. After all, a lot of us, starting out, didn’t have money for fancy jigs and equipment.Too, much of what’s around today was not in the 70’s.
[Oh, and Pinterest pulled this thread up after all these days]
Then there is the “move your blade a single degree and, at the least, double the time it takes to get back to go” thing. As such, we many of us grown our methods and equipment.
View Phil32's profile
Phil32
359 posts in 144 days
#14 posted 01-13-2019 04:21 AM
Most of this thread is pretty old.
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit!
Kelly
#15 posted 01-13-2019 04:40 AM
So, the information is outdated?
