Can I plane this?
Forum topic by SST posted 04-30-2008 01:22 AM 1201 views 0 times favorited 9 replies Add to Favorites Watch
View SST's profile
SST
790 posts in 4434 days
04-30-2008 01:22 AM
Having recently gotten my first planer, and being cheap, as some of you may know, I’m not sure what, besides wood, I’d be able to plane without toasting my cutters.
Oh, I know I’m better off not running boards with nails in them through my planer, but what I’m getting at, specifically, is should I also avoid things like wood glues and fillers. I was thinking that it would be useful to be able to true up a surface after I’ve glued up some boards, or filled the imperfections, but then I got to wondering if I would be better off avoiding that practice. Also, while I’m at it, what about previously finished pieces. Can I use the planer to take the old finish off without prematurely dulling the blades? Thanks. -SST
-- Accuracy is not in your power tool, it's in you
9 replies so far
View trifern's profile
trifern
8135 posts in 4006 days
#1 posted 04-30-2008 01:26 AM
I am no expert, but I think you will be fine with adhesives and finishes as long as they are well cured.
27250 posts in 4061 days
#2 posted 04-30-2008 03:39 AM
I would not use my planer or jointer to try an remove hardened wood glue. Hardened wood glue will chip your knives if you try it. As for removing finishes it can be done but you are risking building a gummy residue on your blades. I have done it on occasion but I generally just get out my belt sander and use it to remove finishes. Sanding belts are much easier and cheaper to replace.
View Betsy's profile
Betsy
3392 posts in 4135 days
#3 posted 04-30-2008 03:45 AM
SST – I’m by no means an expert,,,, but I once used my new planer to remove the finish from several boards that I wanted to redo into shelving. Ruined my knives – did teach me how to change knives though.
Now I think I’d rather use a hand plane that can be resharpened a lot easier——less dust as well. Hand plane to remove the worst of it, then run it through your planer to even up if you need to. (In theory, the hand plane should do the trick without the need to run through the lunch box—- but I’m not good enough to hand plane flat yet.)
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
View jcees's profile
jcees
1071 posts in 4038 days
#4 posted 04-30-2008 04:43 AM
NEVER use your planer to remove finish, glue or any other kind of spooge. Your planer is a dimensioning tool and not a stripping machine. That said, I know a guy who won’t hesitate to swap his blades to do just what you’re asking about. Personally, I’m not that fond of changing the blades on my 15”er. Another friend of mine brought some old lumber over and half of it was coated in some sort of outdoor paint and I told him he was welcome to use the planer to clean his boards if he would have the blades sharpened the day after. Or he could wait for the blades to dull from normal use THEN I’d let him beat the paint off of them BEFORE he took the blades to be sharpened. His wood is still on my stack… waiting.
always,
J.C.
-- When one tugs at a single thing in nature, he finds it attached to the rest of the world. -- John Muir
View GaryK's profile
GaryK
10262 posts in 4227 days
#5 posted 04-30-2008 05:26 AM
I wouldn’t advise it either.
View flink's profile
flink
94 posts in 3959 days
#6 posted 04-30-2008 01:22 PM
Man. I’m glad I read this. I have a bazillion bdft of cherry I was going to run through to take off the stain.
I guess I’m off to HD for some belts.
-- Made lots of sawdust and pounded some nails. Haven't finished anything, though.
trifern
#7 posted 04-30-2008 01:47 PM
Like I said, I’m no expert…
View Toolz's profile
Toolz
1004 posts in 3981 days
#8 posted 04-30-2008 02:52 PM
I use an old cabinet scraper to remove glue squeeze out before running the wood through my planer.
-- Larry "Work like a Captain but Play like a Pirate!"
View SST's profile
SST
#9 posted 05-01-2008 12:46 AM
Thanks to all for the input. That’s what I love about this site. You put up with my stories, and still help me. -SST
