help using japan colors
Forum topic by CharlieMM posted 11-08-2011 07:34 PM 1892 views 0 times favorited 5 replies Add to Favorites Watch
View CharlieMM's profile
CharlieMM
3 posts in 2370 days
11-08-2011 07:34 PM
I have bought some J. E. Moser Japan Color Powders and it is diffwrent than I was expecting.
Could some one explain to me how to use the colors in an oil based finish.
Thanks in advance.
CharlieMM
5 replies so far
View Bill White's profile
Bill White
4907 posts in 3928 days
#1 posted 11-08-2011 07:38 PM
Have you contacted Moser? That’s where I’d start.
Bill
-- bill@magraphics.us
CharlieMM
#2 posted 11-08-2011 07:48 PM
Yes, I called Moser, Platt River something, and I was then refered to Woodworkers Supply. I then called them and got a guy that was supposed to know all about the powders and I still got no answer. I was told that he would call back. So far no callback. Four days now.
Experimention has resulted in MAYBE a method of use but I would love an experienced users input.
Bill White
#3 posted 11-09-2011 12:50 AM
OK! I’ll wade in here. You didn’t expand on your problem, so I’ll tell ya what I’d do.
Mixing the japaning in a stain can be done by adding to an oil-based solution such as varnish or even a “conditioner” by stirring into the solution until you achieve the color you want. A popsicle stick is a good stir stick and it give ya a tasty treat as well. Use a test piece of wood sanded/preped to the same degree as the piece you’re working on.
Are you wiping, brushing, or spraying the finish. By giving us a better idea of your desired result will enable us to help more.
Did you prime the wood with shellac? Is it going to be a paint or stained finish.
Help me help you.
Bill
View hObOmOnk's profile
hObOmOnk
1381 posts in 4095 days
#4 posted 11-09-2011 01:14 AM
Read instructions here.
-- 温故知新
CharlieMM
#5 posted 11-09-2011 04:26 PM
OK folks. Thanks for the input. I got a call from woodworkers supply yesterday evening and all is OK! I got the information I needed and have tried a sample. It looks like everything is going to be fine.
To answer Bill’s question, I have a base color of dye stain applied with a seal coat of dewaxed schellac. I intend to apply poly with a rag/pad with the black color agent mixed into it so I can control the intensity and hoping to get a uniform color.
All this mess was to get a finish to match the furniture in the office, (which I think is awful) or at least in the family. It’s a shame to messup good cherry like that BUT the customer pays well.
Thanks again for the input.
Charlie M
