| Forum topic by SteveKorz | posted 579 days ago | 325 views | 0 times favorited | 16 replies | ![]() |
579 days ago |
Topic tags/keywords: planer curly burl walnut question milling I have a small board of walnut with some sapwood, and it has some fantastic figure in it. However, I can’t seem to plane it without chipout. I’m plaining with the grain, so to speak, not against it. I’ve never worked with wood that has figure in it, and I’m looking for some guidance to plane it so that I can use it. Any ideas? Here are a few parameters. -- As iron sharpens iron, so one man sharpens another. (Proverbs 27:17) † |
579 days ago |
Plane across the grain to level it out. You’ll probably need a plane with a high angle of attack to continue the job “with the grain”. Sounds like the ultimate smoothing of this board may need to be done with a scraper or scraper plane – or sand paper! -- Dorje (pronounced "door-jay"), Seattle, WA |
579 days ago |
If you have already jointed one face, you should be able to use a thickness planer. Here are a few tips that work for me: If you are planing by hand, here are tips that have worked for me: -- Daniel, Southern Indiana -- "Have nothing in your home that you do not know to be useful or believe to be beautiful." -- http://blackdogwoodshop.etsy.com |
579 days ago |
If you’re using an electric planer versus hand planer, there will always be a little tearout since the figure is created by grain switches. Chances are that there will always be some portion of the grain going the “wrong” way. But walnut is more forgiving than hard maple for instance, because the tearout is way less. The suggestions you’ve already gotten are the way to go. As an aside, hard maple is one of the worst for tearout – it usually is pretty deep. The relative hardness of the wood seems to be the biggest factor in tearout. I’ve worked with some quilted maple recently and it was surprising easy to plane without tearout. From the looks of the figure I thought it would be more of a problem. |
579 days ago |
Ditto on Dorje and Blackdog. Both are sound and proven ways to gitterdun! The single most important aspect is what Blackdog makes first in either powered or handwork: Make sure your blade is sharp. That’s gotta be 95% of working wood. Good luck. Always, -- "Imagination is more important than knowledge" -- Albert Einstein |
579 days ago |
when all else fails,go for the cabinet scraper and make sure it has a good burr on it. -- Roper - Master of sawdust- |
579 days ago |
Thanks all for guiding me in the right direction! It’s such a beautiful piece of wood that I hate to junk it just because I can’t tame it…. -- As iron sharpens iron, so one man sharpens another. (Proverbs 27:17) † |
578 days ago |
OR look in the yellow pages for a cabinet or door shop with a drum sander….... -- Odie, Confucius say, "He who laughs at one's self is BUTT of joke". http://woodstermangotwood.blogspot.com/ (my funny blog) |
578 days ago |
Steve, don’t junk it, send it to me. I’ll tame that puppy. HA! always, -- "Imagination is more important than knowledge" -- Albert Einstein |
578 days ago |
Great excuse to buy a new hand plane :) As most know, I use a TON of figured woods…..I’ll reveal my secret: The Lee Valley (Veritas) “Bevel-Up Smoother”. Buy that plane, pick up the optional 50 degree blade, and you will have a glass surface far superior to even a scraper (honestly). Ryan -- If you can't set a good example, at least serve as a horrible warning... www.rarewoodcreations.com |
578 days ago |
I have some hand planes at home, but they need a little work. I can use them to rough out some things, and I have a block plane that does ok, but the big ones need some work (before they work)... lol -- As iron sharpens iron, so one man sharpens another. (Proverbs 27:17) † |
575 days ago |
I have found that a spiral cutter head and/or drum sander are that only thing that leave a nice smooth finish on these type of boards. Would like to see some pics of the board. :) |
575 days ago |
mail it to me with return postage and I’ll run it thru my drum sander -- work from your heart and your spirit will live forever |
575 days ago |
Moisten the wood with some water (make sure you dry the blades after) or mineral spirits (you don’t have to dry the blades). It will soften the grain a little and help to avoid the chip out. -- There is no such thing as scrap wood!, http://www.saltrivergallery.com |
575 days ago |
I go with the spiral planer and jointer blades. I bought my machines for just that purpose. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
574 days ago |
Awesome ideas!!... Thanks all who answered. When I have time to continue milling the board, I’ll let you all know what finally worked… Karson- Just when I thought I had all the machines that I wanted, I see more that I want (with the spiral cutters)... I have an old three blade craftsman planer and jointer… they do the trick, but I’ve found the blades are pretty hard on burly or curly wood. My option at this point is to try and do what BrianM suggested… and moisten it, then hit it hard and repeatedly with a hand plane… I’ve got to sharpen some irons first though… -- As iron sharpens iron, so one man sharpens another. (Proverbs 27:17) † |
572 days ago |
I get away with jointing and planing curly woods and birdseye maple with excellent results as long as the blades are really sharp. Burls I have to sand. Good luck. -- Allen, Milwaukee, WI |
| Forum | Topics |
Woodworking Skill Share
2934 |
3964 |
257 |
956 |
226 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2402 |
LumberJocks.com Site Feedback
525 |
