Need help with using a crown bit without a guide bearing on some cove cuts
Forum topic by ak6143 posted 11-07-2011 03:37 PM 953 views 0 times favorited 3 replies Add to Favorites Watch
View ak6143's profile
ak6143
12 posts in 2687 days
11-07-2011 03:37 PM
I recently cut some larger coves on the table saw (3in wide x 7/8 deep) on some 2 in poplar stock. Now Ive got a crown bit (rockler) that I want to cut a profile on one side of my piece. Ive made a few passes and I think Ive found where I want the depth to be, however without a bearing on the bit, Im confused as to how I accomplish this. Since I am not using the very bottom of the bit (its below the table) I could essentially run the piece forever until I had nothing left. Any input on how I can make a jig or something so that the stock will no longer be cut once I have the depth I like? Thank you
3 replies so far
ak6143
#1 posted 11-07-2011 06:02 PM
One thing I didnt mention, Im using the blue Rockler fence with a wooden fence screwed to it. Because that blue fence is solid all the way from end to end, I cant bring it any closer to the bit because it will hit the fence. I guess the best option is throw a thick shim under the fence, so that the bit will clear the top of the fence as it moves forward?
View HerbC's profile
HerbC
1755 posts in 2855 days
#2 posted 11-07-2011 07:40 PM
Take the rockler fence off and use a temp fence made from a straight piece of wood. Bury the bit in the fence the right depth and alignment to make the cut safely.
Good Luck.
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
ak6143
#3 posted 11-07-2011 09:29 PM
Thanks!
