Time required for hand planing
« back to Hand Tools forum
Forum topic by SeaWitch posted 11-07-2011 07:08 AM 953 views 0 times favorited 2 replies Add to Favorites Watch
View SeaWitch's profile
SeaWitch
149 posts in 2393 days
11-07-2011 07:08 AM
I’d like to ask a question to those who use hand planes instead of a jointer or planer. I don’t want to hijack the other related thread about jointers versus hand planes. I am hoping over time to move to more and more hand tools as my skills improve.
So for those who hand plane boards to make them dead flat on both sides, how long would it take you to do a 6” X 6’ board? Let’s assume your planes are perfectly sharp and you know what you’re doing, and let’s also assume that the grain is relatively straight and not like my avatar.
Thanks.
-- When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it.”   Theodore Roosevelt
2 replies so far
View paratrooper34's profile
paratrooper34
915 posts in 2950 days
#1 posted 11-07-2011 08:20 PM
I would say 15 minutes or so. All you need are planes set up for this work and it is not too bad to get it done.
-- Mike
View drfunk's profile
drfunk
223 posts in 2675 days
#2 posted 11-07-2011 09:11 PM
This is definitely a simple question that has no simple answer. It depends greatly on how much material you have to remove and how smooth you want the surface. I’d say anywhere from 10 minutes for a quick smoothing/scraping to an hour or two to take 1/8” off both sides – using 3 or 4 different types of hand plane/scraper.
Thickness planing is one those areas where electrical tools have a tremendous quality/time advantage – particularly for large pieces.
