I need some help with filling African Mahogany
Forum topic by Angela posted 558 days ago 1835 views 1 time favorited 14 replies Add to Favorites Watch
View Angela's profile
Angela
205 posts in 1061 days
558 days ago
Topic tags/keywords: question filling filler african mahogany
I’ve done a lot of reading about filling so I didn’t think I would be having such a problem but I think all the article are about filling genuine Mahogany and not African Mahogany, which is much more porous.
I’m building a TV stand and I wanted to fill the top. I have stained the top with a water based dye then put a coat of shellc to prtect the wood from any stain the filler might cause. This is what I’ve tried
1. I first purchased the Behlen’s Mahogany oil based wood filler and reducer but every time I’ve tried to use this stuff it just stains the wood black. I’ve tried to reduce it and I’ve tried to immediately removing it after wiping it on.
2. Next I purchased the Behlen’s Natural oil based wood filler. This is a grey color that can be tinted. I first tried it without tinting it and it filled the pores a light grey color so next time I tried to tint it. This was probably the best so far but it still stained the wood and didn’t look right.
3. I thought I’d go another route and try the water based CrystaLac Clear Waterborne Wood Grain Filler that Rockler sells. When I tried this it completely coats the wood and puts a top layer over everything. To remove it from that top of the wood and just leave it in the pores, I sanded the top. The problem is I had to sand too far and it started to remove some of the stain.
4. I then thought I’d try what the magazines and other articles have recommended. One was pumice and BLO (boiled linseed oil). This didn’t really fill the holes, African Mahogany is VERY porous. If I kept rubbing enough pumice into the wood it started to cut into the stain because it was taking too much to fill the holes. Here’s one of the articles about it from FWW
5. I then tried another method of using pumice and a mixture of denatured alcohol and shellac. It did the same as above. “Here's a FWW article regarding this process. I have not tried the Plaster of Paris idea that is mentioned. I’m to the point that I figure I just won’t fill the wood but I really wanted it filled. So I thought I’d ask others out there if they have any ideas of what I can do. I’m not crazy about using oil on the wood because of the change in color. I don’t want to try something less abrasive because the rottenstone will stain the pores black.
Should I add more layer of shellac then try filling it?
-- www.WoodWorkersWebsite.com - Helping other woodworker's
14 replies so far
View PurpLev's profile
PurpLev
7729 posts in 1814 days
#1 posted 558 days ago
What I did was removed the dust collection from my random-orbital-sander and put the dust bag on it, I then sanded the project/mahogany with 220grit prepping the wood for finishing and collecting the sawdust at the same time.
Next, I mixed the sawdust with shellac – it becomes a very thick slur which I then applied liberally over the mahogany – it looks messy, and not very attractive at this point. I then scraped it off using a scraper- trying not to dig into the material, but just scrape the excess after it has dried. the remaining slurr was sealing the pores. you can do a 2nd application just to make sure everything is sealed ,and then use shellac over that as the finish, or whatever other finish you want to use.
View 000's profile
000
3352 posts in 782 days
#2 posted 558 days ago
I’ve never seen filled grain that I liked. It always looks kind of muddy to me.
I suppose if I were hell bent to fill some grain I’d try this:
First a Wash coat of shellac.
Then as many coats as needed of a very heavy cut of super blond dewaxed shellac rubbed into the pores so the shellac ends up filling them. Then sand past the shellac just to the wood and finish with a fast drying urethane like 181
-- When the moderator chooses sides, his site sucks.
View tenontim's profile
tenontim
2129 posts in 1910 days
#3 posted 558 days ago
Angela, I normally wouldn’t stain or dye African mahogany, but to fill the grain here’s what I would do. Watco makes a mahogany danish oil, that may give you the color you’re after. Apply it liberally and sand it by hand with some 400 grit wet/dry sand paper. You’ll have to give it a good work over. Wipe of the excess, across the grain and let dry. Repeat the procedure again. Third time wipe the excess off with the grain. This should give you the mahogany color and the sanding debris will fill in the pores of the wood. I normally do this with a oil/varnish mix, without attempting to change the color of the wood. Good luck.
-- Tim-- http://www.tmuli.com
View Brit's profile
Brit
4183 posts in 1008 days
#4 posted 558 days ago
I filled the grain on a mahogany window sill. I used Behlen’s water-based Mahogany grain filler which was pink in the can. I spread it on a small area at a time using a plastic spreader working at 45 degrees to the grain. It goes off quickly, so you have to work fast. I then hand sanded using a block to just leave the filler in the grain. The I did it again working in the other direction at 45 degrees. After sanding again, the pores were filled with pink filler (a bit scary), but once I applied the top coat which was Liberon Finishing Oil, you couldn’t see it so all was well in the end.
-- Andy -- Old Chinese proverb say: If you think something can't be done, don't interrupt man who is doing it.
View gfadvm's profile
gfadvm
6600 posts in 855 days
#5 posted 558 days ago
Timber Mate wood filler is my favorite grain filler. VERY easy to use. I fill the grain, sand to final grit, and then apply stain (if staining). I have also used BLO and wet sanded with 180 grit to form a slurry which is then worked across the grain with a credit card. The Timber Mate is quicker, easier, and produces good results. It was recently reviewed on this site. Hope this helps. ps Buy the mahogany Timbermate for mahogany, red oak for red oak, etc….
View tomd's profile
tomd
1310 posts in 1936 days
#6 posted 558 days ago
I have been using the Crystalac for a good while now and I like it. I rarely stain wood so I like it because it drys clear and does not leave a muddy look. But when you put it on you must not let it dry, leave it until it gets very thick like puddy then scrape it off with a credit card or similar plastic card. You will then have a very thin coat on top, allow 24 hours to dry completely then sand off the remander with a 320 of 400 grit paper. If you wish to stain do it before using Crystalac.
-- Tom D
View fussy's profile
fussy
963 posts in 1216 days
#7 posted 558 days ago
Angela,
Jeff Jewitt came up with a solution a few years ago. He used plaster of paris. He applied it with a squegee across the grain (after staining and sealing with shellac), wiped it off with burlap going across the grain, then when dry fine sanded to remove the dust. Then he hit it with blo which turns the plaster of paris translucent and showed the color. With a sealed and smooth surface, he applied a finish and the pictures in the magazine ( I believe it was American Woodworker) looked good.
Steve
View live4ever's profile
live4ever
981 posts in 1175 days
#8 posted 558 days ago
I recently used Target Coatings’ High Solids Grain Filler to fill Af Mah. Brush on, let solidify 5 min, scrape off at 45 degrees to grain. Sand. Repeat twice more. This was after a coat of shellac to seal the stain. Top-coated the HSF.with lacquer (EM6000). Came out glass smooth.
View doyoulikegumwood's profile
doyoulikegumwood
384 posts in 2158 days
#9 posted 558 days ago
my favored method for por filling is to use a catalyzed lacquer and build up as many coats as need to be able to rub out the finish. heres the draw back you need to have a good place to finish seid project and have to have some experience with spray finishes.
The nice part about this methode is you dont muddle up the wood with por fillers.
I wood assume as cr1 has pointed out you could also pull this off with shellac but it would be a lengthy process.
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
View 000's profile
000
#10 posted 558 days ago
how many ways to skin the cat?
Now that it’s skinned a dozen ways, how about some recipes for neighbor cat?
View Kelby's profile
Kelby
116 posts in 576 days
#11 posted 557 days ago
Angela,
Try this with a test piece; it’s standard fare for guitar builders.
Get a tube of that 5-minute 2-part epoxy. Mix it and then squish it into the pores and smear it around on the wood using an old credit card. The credit card trick should enable you to squish it into the wood and leave a very light film on the rest of the wood surface. Let it dry.
When it has cured (I usually let it sit a day), sand the wood gently with 180 grit or 220 grit sandpaper. You need to sand until EITHER (a) the epoxy film is flat, but you haven’t sanded through the epoxy anywhere, OR (b) the epoxy film is just barely removed but you haven’t sanded enough to expose additional unfilled pores. (Sometimes I have to epoxy a second time to get a sanded surface that I’m happy with.)
Shellac over the epoxy to avoid any adhesion problems. Once the shellac has cured, sand gently with 220 and then apply whatever finish you wish.
This will completely fill all pores and give you a perfectly flat and smooth surface, while preserving the natural wood look and avoiding having wood that looks like it has been filled with gunk.
If you like the look, most luthiers use something called ZPoxy that you get from luthier’s supply houses. It works great. However, I have also had very good results using 5-minute epoxy and also with West Systems.
-- Kelby
View Dan Lyke's profile
Dan Lyke
1365 posts in 2290 days
#12 posted 536 days ago
I hit my Mahogany with a thinned layer of shellac to seal it before I fill it.
View Byron's profile
Byron
83 posts in 546 days
#13 posted 534 days ago
there’s a great “how to” on filling on http://www.milburnguitars.com/fpgraincontents.html
its part of their french polishing tutorial
-- Byron Conn, Woodworking/Furniture Design at Rochester Institute of Technology, http://byronconn.com
Angela
#14 posted 531 days ago
Well I ended up filling the wood. The problem I was having was the filler was staining the wood even though I had covered it with shellac first but I wasn’t using enough shellac to protect the wood. I was cutting the shellac to much so I used a 2 pound cut and 2 or 3 layers to fully protect the wood.
I used behlen’s mahogany wood filler and it worked great. I filled it twice then I sprayed shellac with my new sprayer from woodcraft. I sprayed 5 coats on because it was put on very thin then I then sprayed 3 coats of rockhard table top varish that was cut 50%. The top came out looking very very nice. I’m amazed how nice it looks. The shellac staph was easy because it dries so fast but with the varnish you need a cleaning environment because it take 3 hours until stuff won’t stick on it.
I’m currently out of the country but when I return I’ll add the finishing and filling photos to my TV stand blog.
Kelby, I might try your idea on another project. I didn’t want to sand to much on this project and i didn’t read your idea until after i had already filled it, but I like the idea.
Thanks everyone!
Angela
