Table Saw Questions
Forum topic by SeaWitch posted 11-06-2011 09:25 PM 1812 views 0 times favorited 14 replies Add to Favorites Watch
View SeaWitch's profile
SeaWitch
149 posts in 2302 days
11-06-2011 09:25 PM
Good Morning All:
I have some rookie Table Saw questions. I have the Bosch portable TS and stand. Now that I’m starting to make cabinets, I’m finding that it’s so small. I’m struggling with should I make a bigger table that surrounds it or just buy a cabinet saw. One question I have is, if I build a table around the existing saw to make it more stationary, can I rewire the on/off switch in some way so it’s on the outside of whatever structure I build? I find the switch is not the most intuitively place as is—I’ll never find it with a larger table.
Thanks
-- When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it.”   Theodore Roosevelt
14 replies so far
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3493 days
#1 posted 11-06-2011 09:28 PM
It can be done but if your not sure get a good well versed friend to help you.Alistair
View ShaneA's profile
ShaneA
6890 posts in 2506 days
#2 posted 11-06-2011 09:52 PM
You would be better served in the long run to upgrade, providing you have space and budget. Bigger heavy saws are easier,safer and quiter to use. Keep the other saw for its portability.
View PurpLev's profile
PurpLev
8534 posts in 3556 days
#3 posted 11-06-2011 09:58 PM
I started with the same saw and when I started getting more interested in larger projects and precision cuts I upgraded it to a heavier saw that also runs an induction motor and is easier on your hearing not to mention it’ll outlast the universal motor on the Bosch in the long run.
I say – upgrade now, one less thing to worry about later.
View knotscott's profile
knotscott
7877 posts in 3283 days
#4 posted 11-06-2011 10:11 PM
I’d just go for the upgrade, whether a cabinet saw, contractor saw, or hybrid. Portables are great for lugging to other jobsites, but all the other advantages go to a good stationary saw. Table space, especially in front of the blade is a big advantage. Mass and stability, more torque, smoother quieter operation, easy upgrades, plentiful accessories, better long term reliability, resale value, and feasibility of repairs are just some of the other advantages.
View richgreer's profile
richgreer
4541 posts in 2982 days
#5 posted 11-06-2011 10:21 PM
I don’t know this for a fact, but I suspect your portable TS has a universal motor. Cabinet and hybrid saws have induction motors. Induction motors are heavier, but they are also quieter and the last a lot longer. You really want an induction motor on your table saw.
View HerbC's profile
HerbC
1721 posts in 2767 days
#6 posted 11-07-2011 04:54 AM
CR1,
Zip code saws???
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
knotscott
#7 posted 11-07-2011 04:07 PM
“Zip code saws” were a nick name given to the early Craftsman hybrid saws made by Steel City/Orion because of their model numbers… 22104, 22114, and 22124, (which is actually the zip for Oakton, VA) . IIRC, it originated over at Woodnet ~ 2005.
View RogerM's profile
RogerM
790 posts in 2307 days
#8 posted 11-07-2011 04:42 PM
Go for the upgraded table saw. You will experience a notable difference in power, accuracy and reliability. You might try Redmund & Sons (http://www.redmondmachinery.com/) in Atlanta. They often have some real good buys on factory reconditioned equipment and usually have a good selection of cabinet saws to choose from.
-- Roger M, Aiken, SC
View JERRY54's profile
JERRY54
21 posts in 2302 days
#9 posted 11-09-2011 05:33 PM
I took a old junk sears tablesaw made a top & put on a delta fence, it works very well for breaking down plywood and other typs of sheeting. The blade tilt didnot work right so i just covered the whole top of saw, I have a dewalt TS i use for bevel cuts & sled, That delta fence is just great and dead on. On off switch i got from rockler works great.
View crank49's profile
crank49
4029 posts in 2879 days
#10 posted 11-09-2011 06:02 PM
The after market switches have a plug on a long cord to connect to the power source (outlet) and a short cord with a socket on the end where you lug in your existing power cord from the saw. Some of them have an outlet on the switch instead of the short cord. You just turn the saw’s existing switch on and leave it. Use the new switch to operate the saw. Good example in the last picture of Jerry54’s post above.
These switches are handy for other jobs too. I have one to turn on my dust collector. Will probably have another one for my router table; if I ever get time to build it.
View mcase's profile
mcase
446 posts in 3037 days
#11 posted 11-10-2011 01:43 AM
Cool work Jerry!
View jeff's profile
jeff
1063 posts in 3372 days
#12 posted 11-10-2011 05:46 AM
that is some nice work Jerry…
-- Jeff,Tucson,Az.
SeaWitch
#13 posted 11-10-2011 06:13 AM
Wow Jerry54, that’s fantastic work!
JERRY54
#14 posted 11-10-2011 04:51 PM
Thanks guys
