Old hinge on kitchen cabinet door
Forum topic by Eric posted 11-06-2011 09:07 AM 9832 views 0 times favorited 10 replies Add to Favorites Watch
View Eric's profile
Eric
52 posts in 3087 days
11-06-2011 09:07 AM
So I am fixing a few kitchen cabinet doors for a friend.
They are missing a few hinges.
Has any one seen or know where I could buy hinges like you see in the picture?
-- Eric "That's all very well and human, but when will you stop having to apologize and start doing your very best you can? When will you begin?"
10 replies so far
View Lee Barker's profile
Lee Barker
2170 posts in 2851 days
#1 posted 11-06-2011 08:34 PM
Those are called single demountable hinges, by Amerock most likely.
I Googled and found lots of references; here is one that is close:
I sometimes see these at my local Habitat For Humanity ReStore.
You’ll need to know the overlay of your doors to get the right one via the ‘net.
I think it’s a solvable problem, my favorite kind. : )
Kindly,
View oluf's profile
oluf
260 posts in 3039 days
#2 posted 11-07-2011 05:43 AM
That hinge looks like it came off of a factory made metal door. Not a wooden door. I say that because of the large metal washer rather than screw holes to attach to the inside surface of the door.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
View Grandpa's profile
Grandpa
3259 posts in 2676 days
#3 posted 11-07-2011 05:46 AM
I have some reclaim cabinets that I am using in my shop. The hinges are like the one in the photo so I have seen them used on cabinets with wood doors. I don’t know where they got them but they were on some cabinets probably built in the ‘70’s
View johnsonj's profile
johnsonj
4 posts in 2399 days
#4 posted 11-07-2011 06:28 AM
Ha ha ha. Enjoy the hell out of that one. My mother in law has similar hinges (wrap around vs the outside mounting). First off, they are a royal pain to find. There is a place here in Dallas called Elliot’s hardware that actually carries these.
I had to replace two of her kitchen doors and my first thought was, “How in creation do I cut that slot? There has to be something special that made it.” My first thought was it had to be some router bit. But then I was asking myself, “Who in 1975 had a router?” Shaper? Maybe.
Since her’s were hidden, I ended up using a bronze matching semi wrap w/ the same offset and std 3 screws.
View OurMom's profile
OurMom
2 posts in 1350 days
#5 posted 09-15-2014 03:33 PM
I have cabinets installed in 1989, and they are kind of like the ones above. But my cabinets no longer close flush. They are not lined up properly. Can these be adjusted?
View Eric's profile
Eric
#6 posted 09-18-2014 01:55 PM
I am pretty sure these hinges can not be adjusted.
OurMom
#7 posted 09-27-2014 01:30 PM
Crap. Thanks Eric.
View jerryminer's profile
jerryminer
923 posts in 1442 days
#8 posted 09-27-2014 05:25 PM
- Eric
There IS typically some adjustment in these demountable hinges. The single screw in the back essentially clamps the hinge to the door. There is some movement in the slot once the screw is loosened a bit, so:
Loosen the screw, adjust the door, tighten the screw.
View seebsno2's profile
seebsno2
1 post in 1285 days
#9 posted 11-19-2014 08:33 PM
I have the hinges in this picture…what are they called and where can I get them?
jerryminer
#10 posted 11-20-2014 01:39 AM
Those are called “double demountable” hinges. Here is one source:
WW Hardware
If you’re just replacing, you will need to know the “overlay” dimension—the amount by which the door overlaps the opening—-looks like maybe 1/2” in your pic.
If you’re starting from scratch, you will need a special router bit (and some jigging) to cut the slots.
