Rattle Can Spray Paint
Forum topic by dpwalker posted 11-04-2011 07:03 PM 1256 views 0 times favorited 5 replies Add to Favorites Watch
View dpwalker's profile
dpwalker
273 posts in 3071 days
11-04-2011 07:03 PM
I am wondering what kind of rattle can spray paint LJ’s are using. I built a piano bench from poplar & used 3 coats of Rustoleum spray primer (dried thoroughly) & finished spraying with Rustoleum indoor/outdoor gloss black paint. The primer held up fine but the black paint is flaking off to the primer. I don’t know how many coats of paint I’ve used but I have gone thru 4 cans trying to get the paint to stick. Is there a better paint someone could recommend ?
-- You have not really lived until you do something for someone who can never repay you.
5 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 3308 days
#1 posted 11-04-2011 07:20 PM
Rustoleum is a pretty good paint so I would wonder if you were using paint formulated for wood and are your paint and primer compatible. I’ve never had a problem with Rustoleum paints.
I’ve had very good luck with ACE “Stain Halt” primer and ACE spray cans, too.
View TravisD's profile
TravisD
4 posts in 2632 days
#2 posted 11-08-2011 07:23 PM
I would suggest ACE brand Premium high gloss enamal spray paint. It leaves a high gloss durable finish. I used it on some old putty knife handles. One coat of primer and then two coats of the Ace paint. It has lasted for a year now with moderate use.
-- Travis - Shenandoah Valley VA
View Bill White's profile (online now)
Bill White
5149 posts in 4200 days
#3 posted 11-08-2011 07:27 PM
Stupid ? here. Did you sand between primer and finish coats? There shouldn’t be any binding probs when using same-brand primer and finish.
Bill
-- bill@magraphics.us
TravisD
#4 posted 11-08-2011 07:34 PM
I also used it on an old jig saw base plate that i refurbished and it has held up very well on the bottom with all of the friction against the boards.
dpwalker
#5 posted 11-09-2011 06:35 AM
Ok. I stripped the bench & started over. Two coats of primer then paint. It seems to be holding up pretty well. Maybe I got my hands on old paint? Any way It seems to have taken this time. AND just to be sure I let it dry 24 hours then finished it with polyurethane.
Bill White – yes I did sand lightly between coats. I thought that alone would keep the paint from separating. No luck there.
Any way I thank you all for your replies & help.
