Making a chisel (slick)
« back to Hand Tools forum
Forum topic by planeBill posted 11-04-2011 06:00 AM 2163 views 0 times favorited 4 replies Add to Favorites Watch
View planeBill's profile
planeBill
506 posts in 2432 days
11-04-2011 06:00 AM
Hello fella’s, I would like to ask a question that hopefully someone can help me with. I want to make a slick for my boatbuilding project I am going to finally get going on as soon as my wife is satisfied with her(our) furniture.
I have some perfectly sized pieces of spring steel, which is new, that I would like to use to make a 3” slick. My question is, would spring steel, which I was told was 5160 (?) steel, make a good chisel (slick)? If so, what should I be aware of as far as tempering, quenching, etc…? I have already ground a 30 degree bevel on it, very slowly with a bucket of cold water beside the grinder to keep it cool and I did it a very little at a time and at no time did the steel ever become too hot to touch with my bare fingers. The bevel, which is still in the rough, was the easy part but I figured I would ask about the suitability of the material before going on with the shaping and drilling and tapping for the handle.
Thanks in advance for any advice.
-- I was born at a very young age, as I grew up, I got older.
View BobE's profile
BobE
28 posts in 2976 days
#1 posted 11-04-2011 07:41 PM
I’m interested in making my own drawknife out of some scrap high carbon steel I’ve acquired. So, I’ve been researching the same sort of stuff the last couple of days. I’m not sure I’m qualified enough to answer, but I’ve been finding a lot of good information on knife making forums.
planeBill
#2 posted 11-05-2011 12:39 AM
Good idea Bob. I should have thought of that
View David Kirtley's profile
David Kirtley
1286 posts in 3021 days
#3 posted 11-05-2011 02:12 AM
Springs are not left as hard as a cutting tool. You will need to reharden and temper so it doesn’t really matter if it overheats a bit while shaping. The grade should be fine. Going to take a lot of heat and a lot of water to do something that big.
planeBill
#4 posted 11-05-2011 03:12 AM
David, Thanks for that info. It’s not a very big piece so my little BBQ kiln should work.
