chisel help, kind of a dumb mistake
« back to Hand Tools forum
Forum topic by maljr1980 posted 11-04-2011 05:30 AM 720 views 0 times favorited 2 replies Add to Favorites Watch
View maljr1980's profile
maljr1980
171 posts in 2358 days
11-04-2011 05:30 AM
okay so i have some oxidation starting to occur on my chisels, so while i was at work i took a red scrotch brite pad and tried to buff out my 1” chisel. it is a pfeil cabinetmakers chisel. it has left my chisel dull looking. how can i bring back the shine? the chisel is also laser etched with the pfeil logo and size, etc, which i dont want to remove either
2 replies so far
View drfunk's profile
drfunk
223 posts in 2579 days
#1 posted 11-04-2011 07:18 AM
Next time use steel wool with mineral spirits.
I don’t know of any other effective way to polish high carbon steel than to step down through several grades of steel wool (with mineral spirits as a lubricant) and then finish up with a polishing wheel with compound. I would assume your etch would be ok as long as you don’t polish that area too aggressively with the steel wool.
View thedude50's profile
thedude50
3602 posts in 2380 days
#2 posted 11-04-2011 07:36 AM
I say use a buffer a red is a fine grade and wont have roughed it enough to be a big problem ya a buffer will fo a fine job.
-- Please check out my new stores http://woodratnest.com and http://woodshopstore.com
