bowl gouge sharpening
Forum topic by D_Allen posted 11-04-2011 03:34 AM 8189 views 1 time favorited 8 replies Add to Favorites Watch
View D_Allen's profile
D_Allen
495 posts in 2780 days
11-04-2011 03:34 AM
I’m looking for some experienced grinders.
I got a bowl gouge today and tried to re-sharpen it. It wasn’t sharp enough in my view, but it did cut. WELL, it cut pretty WELL. Anyway, all’s WELL that ends WELL! Good grief!.
Anyway, this is what it looks like. It is real close to what it was originally.
I would like to do a side grind, like this…....sometimes called an Irish grind.
From what I have seem on videos it is necessary to use the pivot jig in such a way as to have the tool on a steep angle with the handle down. I made a jig with a 45 degree pivot. When I sharpened it the tool was level at the midway point.
Can I achieve that grind on this shape tool?
Any suggestions would be appreciated.
And by the way, my confidence has been restored after trying both the bowl gouge abd a 1/2” roughing gouge.
You’re gonna know when the edge cuts clean and right.
-- Website is finally up and running....www.woodandwrite.com
8 replies so far
16274 posts in 4215 days
#1 posted 11-04-2011 05:14 AM
I have not really experimented with custom grinds much, but I’ve seen quite a few turners say they like to experiment with non-standard edges.
View doordude's profile
doordude
1085 posts in 2979 days
#2 posted 11-04-2011 05:24 AM
Sure, you buy a wolverine jig and and a slow speed grinder, and you can put any kind edge you want on it.
your going to need it eventually anyway.
10381 posts in 3644 days
#3 posted 11-04-2011 07:51 AM
Dunno about jigs, but you can grind that shape freehand. If you’ve never
turned much with a standard bowl gouge however, I’d recommend you
start with a less aggressive modification to the stock grind.
I’m not a big shot at turning, and that Irish grind looks interesting but
it also looks like it might introduce its own set of handling problems
that may be no better, all compromises considered, than a more
common grind. The standard bowl grind is not very interesting, but
it does work and manage heat well and can both cut and scrape.
View hairy's profile
hairy
2701 posts in 3528 days
#4 posted 11-04-2011 03:09 PM
youtube has lots of videos , mostly with a special jig.
This one is without a jig. http://www.youtube.com/watch?v=4m8-8MNhpvY&feature=results_video&playnext=1&list=PLB26F4A913A3095AF
-- My reality check bounced...
View mtenterprises's profile
mtenterprises
933 posts in 2689 days
#5 posted 11-09-2011 05:31 PM
This is what you want http://www.youtube.com/watch?v=5i9RDnJHz9g
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View Chris 's profile
Chris
1879 posts in 3987 days
#6 posted 11-09-2011 06:44 PM
I have reground a standard one to the Irish or fingernail grind. I had a link that to a step by step… I will try to find it and post it for you
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
D_Allen
#7 posted 11-13-2011 03:55 PM
Here is my version based on a lot of information gathered on the web.
It uses a u-bolt that squeezes the tool against the top leg of an angle.
I checked the alignment and the mounted tool is square to the pivot post.
That post was turned on the lathe off-center so that the arm was in line with the tool when mounted.
I sharpened both the bowl gouge and spindle gouge with it and am pleased with the results.
However, I will need to make some modifications to get the Ellsworth grind. Still working on that.
D_Allen
#8 posted 11-20-2011 09:42 PM
OK, I had to make some modifications. At one point I was real close to buying the veri-grind, and I still may.
With just one u-bolt it allowed the tool to wander side-to-side. This holder is similar to the veri-grind.
I also made a more substantial pivot section.
I also made this finger saver. Not pretty but it works. At one point today I had a catch with a spindle gouge and it got me to thinking that if such a catch forced my knuckles against the chuck, it could be very messy.
