Tack Trunk Wood choice
Forum topic by revz posted 566 days ago 1356 views 0 times favorited 6 replies Add to Favorites Watch
View revz's profile
revz
9 posts in 1358 days
566 days ago
I am building my daughter a tack trunk. I have noticed that most build them from plywood and edge the box with a hardwood. My preference is always to use hardwoods. All the furniture I have made is either solid cherry or walnut. I would like to use Mahogany to edge the box but I would prefer to use a hardwood to build the box itself.
Is there an affordable hardwood that would serve as a good alternative to a plywood that would stain well compared to real mahogany?
Robert
-- Robert, Reformed Woodworker
View 000's profile
000
3352 posts in 786 days
#1 posted 566 days ago
Hardwoods are spendy is because there is not as much of it as there are soft woods like pine or inferior woods like poplar. So a good hardwood will be spendy.
When you say Tack Trunk do you also mean a place for the saddle?
I’d go with cedar just because it smells nice. It’ll wear in a way that is evocative of the out of doors and horses too, I should think.
I never contemplated putting my tack or saddles in a box. I prefer to let them air out hanging in the open.
-- When the moderator chooses sides, his site sucks.
View northwoodsman's profile
northwoodsman
227 posts in 1915 days
#2 posted 566 days ago
Quarter sawn white oak or hickory?
-- NorthWoodsMan
View revz's profile
revz
#3 posted 566 days ago
Thanks for your reply
It is for english equestrian riding and it will be a show tack trunk. The stable where she rides, her saddle and accessories are handing, but the tack trunk would hold cleaning supplies, bandages, etc… Most of the girls have trunks purchased (ranging from 500-900) Construction is plywood and hardwood trim. It is does serve a utilitarian purpose, but it is supposed to be a show piece.
The trunks are indoors, in dry conditions. I m leaning toward using a cheaper hardwood for the box construction and trimming it with mahogany.
Most use a spruce or marine grade plywood, but my experience with plywood is limited. I prefer hardwoods.
I don’t know if a spruce hardwood would suffice. I am assuming that spruce is far more affordable than cherry or mahogany
View revz's profile
revz
#4 posted 566 days ago
Opps, I mean either ash, poplar, or birch as an affordable hardwood. Any thoughts?
View oluf's profile
oluf
252 posts in 1208 days
#5 posted 565 days ago
I would not use solid hardwood for a project like this. The box would be way too heavy. I would use a good quality hardwood venired plywood. You can edge band the plywood so the edge grain does not show. Your box will be stronger, more stable, and take any fine finish you chose to wse.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
View MOJOE's profile
MOJOE
533 posts in 1438 days
#6 posted 565 days ago
I think ash would look pretty nice trimmed in mahagany…..plus, here in KC, ash is not overly expensive.
-- Measuring twice and cutting once only works if you read the tape correctly!
