Has anyone here built a Copy Carver ?
Forum topic by David Grimes posted 593 days ago 1610 views 0 times favorited 15 replies Add to Favorites Watch
View David Grimes's profile
David Grimes
2065 posts in 836 days
593 days ago
http://www.copycarver.com/index.htm
This DIY machine seems to be somewhere in the middle of the woodworking quotient between CNC and hand carving. So if I have my original, I can make nearly finished copies without all the labor pains of the original work. I like that concept a lot.
I’m just wondering if anyone has built one.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
15 replies so far
TopamaxSurvivor
13179 posts in 1872 days
#1 posted 593 days ago
No, but I bought a factory made duplicator for next to nothing from a guy i got some other WW tools from. Haven’t done anything with it yet. Can’t pass up a deal ;-))
-- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence
David Grimes
#2 posted 593 days ago
Me neither, Topa :=)
View philip marcou's profile
philip marcou
259 posts in 793 days
#3 posted 593 days ago
No, it is cheating….(;)
David Grimes
#4 posted 593 days ago
...and your point is ? ;=)
But, but if I carve the original and like it, then I can make more from it. It’s woodworking propagation. Picasso made prints from his originals. Stradivarius let his indentured servants (I mean apprentices) copy his work, then pass them off as his work. C’mon, Phil !?
View Don W's profile
Don W
10209 posts in 764 days
#5 posted 593 days ago
I have thought about it a couple of time. I would be interested to know how it works.
View helluvawreck's profile
helluvawreck
10904 posts in 1063 days
#6 posted 593 days ago
There’s nothing wrong with it. Different strokes for different folks sooo to each his own. A lot of caracature carvers and others as well use similar machines to make their rough outs and do the rest by hand. People also sell rough outs to other people. If you want to do the whole carving with one of these that’s fine too.
View YBNORMAL's profile
YBNORMAL
37 posts in 627 days
#7 posted 593 days ago
Havent built one, But there are several threads in other forums that show enought detail to build it without the plans. Just google it.
Here is a better design, that looks simple enough to build without a lot of hassle.
http://www.wood-carver.com/
Rs
YBNORMAL!
View jim C's profile
jim C
1384 posts in 1295 days
#8 posted 593 days ago
Holy smokes, $2750.00 for the wood-carver!
I can buy a pretty fair N.C. router for that much.
It looks easy enough to build for about $200.00 in parts and another $150.00 for the router.
-- Government does not solve problems; it subsidizes them.
David Grimes
#9 posted 593 days ago
@YBNORMAL, I had come across the Gemini and would refer to it as well if I build a duplicator. I need one of these for carving the book matched Les Paul (and other) tops you are going to find for me ;=)
@cr1, If you are referring to the power head on the Copy Carver, I’m pretty sure that is a cheap Ryobi laminate trimmer with the base and all the plastic handle and housing removed. He actually recommends the ones that have an all metal motor housing. I’ll just pull the feet and britches off a Dewalt I already have.
View Letorix's profile
Letorix
119 posts in 700 days
#10 posted 592 days ago
David Grimes
#11 posted 592 days ago
Yeah, I saw that before. Can’t go by the one shot whether it’s any good or not. The one picture I believe I could do with a mirror and a hatchet. ;=)
David Grimes
#12 posted 586 days ago
IF I build this, I already see from the plans I purchased that the fixed height lets the probe and router tilt (not plumb most of the time). There will be times when that would present a problem. So I will have to either make it “z” adjustable by either allowing for the raising or lowing of the tool platform (rails).... or building simultaneous tilt adjust into the probe and router. Hmmm.
View Gene Howe's profile
Gene Howe
3216 posts in 1625 days
#13 posted 586 days ago
I have the plans, David. It’s on my to do list.
Looks simple enough for me.
View devann's profile
devann
1711 posts in 889 days
#14 posted 585 days ago
Check out this LJ David. This might help. He does some interesting stuff. http://lumberjocks.com/projects/45811
David Grimes
#15 posted 585 days ago
@devann, that is very interesting but sounds like he’s nesting routers. At this time I’m torn between a Copy Carver build and the purchase of a Marlin. The Copy Carver being made from wood is actually the only negative in my mind (there… I said it). Still pondering. Thanks for the link.
