| Forum topic by Carl Webster | posted 566 days ago | 1506 views | 0 times favorited | 17 replies | ![]() |
566 days ago |
I have an older model Craftsman table saw built by Emerson Electric. The model # is 113.298031. The casting that houses the blade arbor rotates around a shaft on a fixed casting as the blade is raised or lowered by a rack and pinion mechanism. The casting housing the blade arbor is “frozen” on the shaft and will not allow the blade to be raised or lowered. I have soaked the area with a product called PB Blaster to no avail. Any ideas as to how I can remove the blade arbor casting to free up the mechanism? -- Carl in SC |
17 replies so far
#1 posted 566 days ago |
Take a propane torch to it. Guard areas around it from the heat if There are other methods, of course, but when sprays aren’t doing |
#2 posted 566 days ago |
Carl, some saws have a manual locking mechanism to keep the blade from moving due to vibration. Don’t know about your saw, but mine has one for the tilt position. I hope this is helpful, as I may be totally misreading your post and could be off on another planet. :-) -- Randy, Tupelo, MS ~ A man who honors his wife will have children who honor their father. |
#3 posted 566 days ago |
Loren and Randy Sharp, From your recommendations it’s ovious that I have not explained my problem clearly enough for you to understand what I am talking about. There is a shaft approximately 5/8 inch in diameter that the blade arbor housing/casting rotates around as the blade is raised or lowered. The referenced housing is jamed on the 5/8 inch shaft and won’t alow the blade to move up or down. The same housing/casting has the “rack” machined in it for the blade raising worm to ride in to raise or lower the blade. I’m sure the problem is due to lack of lubrication and is probably due to a buildup of rust/corrosion. I have tried heat from a propane torch and an acetylene torch to no avail. I guess I’ll have to try to get it hotter. It’s a fair sized casting and hard to get heated up. -- Carl in SC |
#4 posted 566 days ago |
Don’t heat it. That risks destroying heat treated components. I think PB blaster is just teflon. Try Sea Foam Deep Creep. Best penetrant I’ve tried yet save for plant extract wintergreen oil you can get at a pharmacy (not the synthetic stuff). It’s jammed and won’t go in either direction? It might not be jammed at the threaded shaft but in the trunnion. What you haven’t said is whether this is a saw that was in storage or regular use. Also there are limit collars on the threaded shafts. They adjust with a set screw. Are they in the proper positions? -- When the moderator chooses sides, his site sucks. |
#5 posted 566 days ago |
The saw is in use practically every day and the blade is lowered every night and raised the next day. Thanks for your input. The saw is jamed in the trunion which is held to the fixed casting by 2 washers and a “c” clip. -- Carl in SC |
#6 posted 566 days ago |
I may be time to do some disassembly. -- When the moderator chooses sides, his site sucks. |
#7 posted 566 days ago |
Have you tried the time honored tradition of hitting it with a hammer? I’m not joking. PB Blaster is useless. Kroil will work if that’s the problem. -- It must be jelly baby, cause jam don't shake like that... |
#8 posted 565 days ago |
The saw is dissemblied except for removing the trunion from the casting it is “jamed” on. This is the problem. In addition to being jamed I cannot remove it to “clean” the shaft it is jamed onto. And yes I have tried the time honored tradition of hitting it with a hammer. I guess the next approach is to try to use some type of gear puller to pull it off. -- Carl in SC |
#9 posted 565 days ago |
I wouldn’t hit cast iron. It’s got a lousy modulus of elasticity. -- When the moderator chooses sides, his site sucks. |
#10 posted 565 days ago |
No more fasteners. It is held on by a washer and “c” snap clip which have been removed. Thanks for sticking with me guys!! By the way is Kroil available anywhere other than ordering on the Internet? -- Carl in SC |
#11 posted 565 days ago |
Is there any adjustment on the rack and pinion mechanism for the rise and fall? My saw has jammed on a couple of occasions, the culprit has always been the gears managing somehow to get too tight into each other. -- Do or do not, there is no try |
#12 posted 565 days ago |
The pinion shaft has been removed as the saw was disassembled. The casting which the blade arbor is mounted on is “frozen” and will only rotate when hit with a dead blow hammer. -- Carl in SC |
#13 posted 565 days ago |
Kroil should be available in auto parts type stores. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#14 posted 565 days ago |
crank49, thanks for the tip on Kroil. I had called one of the local auto parts stores and they did not stock it. -- Carl in SC |
#15 posted 565 days ago |
he pinion shaft has been removed as the saw was disassembled. The casting which the blade arbor is mounted on is “frozen” and will only rotate when hit with a dead blow hammer. It’s out of the saw and on a bench and it’s still jammed? -- When the moderator chooses sides, his site sucks. |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3550 |
15784 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
