| Forum topic by DS | posted 594 days ago | 1781 views | 0 times favorited | 17 replies | ![]() |
594 days ago |
Topic tags/keywords: question tip When I built my first violin, the book I was following made a big deal about the finish. How the finish affects the sound quality and how modern finishes can diminish the tone of a violin. There were several cited sources for old-timey recipes for varnish, but what surprised me most was it called for egg whites to be used as a sealer coat prior to varnish. Nervous about getting it wrong, I was a bit hesitant to use raw egg whites to seal the violin prior to coating with varnish.. After all I just spent a couple months getting this thing assembled somewhat correctly. After trying it out, I was pleasently surprised how well it worked. It’s like nature’s sanding sealer. Amazing! I still use egg whites and varnish on my instruments, but haven’t dared use this on any of my paying customers’ furniture gigs. Has anyone else heard of this? -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
17 replies so far
#1 posted 594 days ago |
How did you prepare the whites and then how did you apply it. I never heard of that before. Talk about a “green” finish!!! -- Drew -- "I cut it twice and it's still too short!"- Rock-n H Woodshop - Moore, OK |
#2 posted 594 days ago |
Super simple… Cracked an egg and seperated the yolk from the white… whisked it gently with a fork in a small bowl and used a soft varnish brush for the application. Try to avoid getting the foamy bubbles in the finish. It sands out nicely when dry. (Started at 1200 grit on the egg whites… 2400 Grit between varnish coats, 9600 grit on the final coat.) The interior of a violin has only this treatment to it—no varnish in there. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#3 posted 594 days ago |
In photography to make albumen prints (egg white) we used to mix the egg white with vinegar to prevent mold formation, you might want to try that as well. If it works for paper I am sure it will work for wood. Paper comes from wood, right? :) -- Just because you’ve always done it that way doesn’t mean it’s not incredibly stupid. |
#4 posted 594 days ago |
DS251 I would love to hear more about making violins. Where did you learn? -- Make furniture that lasts as long as the tree - Ryan |
#5 posted 594 days ago |
RGTools: I found a book one day while I was at the local Rocklers. Violinmaking for Amatuers. After that, I figured out that the Pro’s make them somewhat differently. I checked out lots of books from the library. I bought a couple awesome reference books, bought some of the specialty tools and brought in some nice imported tonewoods. I’ve since turned out some fairly nice instruments. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#6 posted 594 days ago |
Egg whites were also used as additive to mortar in medieval times and as glue in some applications until fairly recently. |
#7 posted 594 days ago |
egg , buttermilk, and oxblood is some of the traditonel ingrreedience´s in the old here in Denmark they are all called milkpaints by people who don´t know the different here is two site´s with some recipie´s you can look …........sorry they are in Danish http://www.slideshare.net/thylander/20-Malings-opskrifter-Raadvad http://www.antikabc.dk/frontpage.aspx?id=0&type=6&dbid=6821 so there is no reason to fear using egg good luck :-) Dennis |
#8 posted 594 days ago |
I for got to say on this little island in a near by village there is a house where the frontdoor Dennis |
#9 posted 594 days ago |
I get asked all the time if I play. Most people assume that I do. The fact is, I can carve, but, sadly, cannot play. I have “fat” fingers that refuse to behave properly on the strings! I do play many other instruments though and am quite the music affionato. Fortunately, I have many family members who do play, including my sister who plays in the local symphony, my daughter and a nephew who also play. They each have an instrument made especially for them. I get several opinions of an instrument by the “experts” before it is finalized. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#10 posted 594 days ago |
Do you mean Egg White Glair? -- 温故知新 |
#11 posted 594 days ago |
I use Knox gelatin as a glue. I mix it a little stronger than on the package in a glass jam jar. To keep it liquid I place it on a coffee warmer. I use a small paint brush to apply it. |
#12 posted 594 days ago |
Ok, Bro. Tenzin what kind of things do you use Egg White Glair for and Zuki, what kind of things do you use gelatin glue for? -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#13 posted 593 days ago |
:-) you never know what happens around halloween Dennis |
#14 posted 593 days ago |
So Dennis, you keep the IV Blood Bag with the paint roller and pan, do ya? -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#15 posted 593 days ago |
| Forum | Topics |
Woodworking Skill Share
8846 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15978 |
Hand Tools
2095 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2776 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
