Gluing cedar boards
Forum topic by MyFathersSon posted 11-02-2011 05:28 PM 7759 views 0 times favorited 7 replies Add to Favorites Watch
View MyFathersSon's profile
MyFathersSon
180 posts in 3462 days
11-02-2011 05:28 PM
Topic tags/keywords: question cedar arts and crafts joining
I need to make some roughly 4×6 cedar posts 10’ long.
The wide face will be the front.
So far no luck finding anything that dimiension so I am looking at gluing up three 1×6 boards.
Have heard that cedar is finnicky about glue.
Never tried it.
Any recommendations as to the best glue to use or anything else I need to do or not do would be most welcome.
-- Those who insist it can't be done - should politely refrain from interrupting those who are doing it.
7 replies so far
View crank49's profile
crank49
4032 posts in 3119 days
#1 posted 11-02-2011 05:56 PM
Three 1×6s will only be a glue-up of 2-1/4×5-1/2. Is that big enough?
Epoxy will bond pretty much anything but polyethelyne, I think.
MyFathersSon
#2 posted 11-02-2011 06:06 PM
OOPS—TYPO on my part—
should read 3 TWOx6 boards (4.5”x5.5”)
I have found a source for a 4×6 post (3.5×5.5)
This is one inch thinner than originally spec’d
SO—now I have a side question
These posts will be supporting a 4’x5’ sign at a top height of about 7’
(30”-36” in the ground)
As for ability to stand up to the wind etc—
Will I be better off going with the glue ups for the extra thickness?
Or will I be just as safe (or safer) with the solid post. ????
View danr's profile
danr
154 posts in 3333 days
#3 posted 11-02-2011 06:08 PM
Western Red or aromatic Cedar?
I have glued both with just a good exterior grade glue like tite-bond.
To convince yourself you could make some “small piece” glue ups and test them.
MyFathersSon
#4 posted 11-02-2011 06:14 PM
danr -
I’m a cedar novice (hence my concern about gluing)
If I go with the 2×6 glue ups—Im talking the cedar boards at the Big Blue Box.
Not sure which it is.
If I go with the solid post – Im talking aromatic cedar from a ‘actual lumber yard’
crank49
#5 posted 11-02-2011 06:56 PM
You will want 3 feet in the ground if possible, with concrete poured around them from a bell shaped bottom all the way to the top.
If I couldn’t get 3 feet in the ground, I’d make the hole a little bigger to compensate.
View BreakingBoardom's profile
BreakingBoardom
615 posts in 3230 days
#6 posted 11-02-2011 07:06 PM
Have you checked to see if they sell 6×6 cedar posts where you are that you could rip down to your desired size, or that you could just use as is to hold up your sign? Or have you thought about using pressure treated lumber? I know it comes in 6×6 posts.
-- Matt - http://breakingboardom.wordpress.com/
MyFathersSon
#7 posted 11-04-2011 02:57 AM
Crank49—
I recommended those things to them regarding installation.
But I spelled out clearly in the contract that installation – as well as any permitting, code requirements etc are their responsibility. Mine ends when the job is done to their specifications and satisfaction.
I dont have the tools or inclination to get involved in post hole digging etc.
Breaking—
Yes—I suggested treated lumber as an option but they specifically want cedar.
From the feedback I got on here and elsewhere it appears that gluing up cedar is not as problematic as I thought it might be. So—I went ahead with my original plans of using 2×6s from the big blue box.
That also allowed me to rent their truck to haul the materials home in.
I guess time will tell if I made a wise choice.
