Banding a Round Table
Forum topic by Christopher Frank posted 11-02-2011 01:04 PM 3392 views 0 times favorited 6 replies Add to Favorites Watch
View Christopher Frank's profile
Christopher Frank
11 posts in 3714 days
11-02-2011 01:04 PM
I’m going to be building a round table that has a 2” MDF core and will be veneered on the top and bottom. I need to band the edge. Is it best to use very thin banding or veneer? What is the best method for applying it to the core?
View Nomad62's profile
726 posts in 2892 days
#1 posted 11-02-2011 05:19 PM
A lot of people like the iron on edge bands, they are easy to use. If you want to use your own wood then slice it around 1/8” thick and you can use ratcheting straps with cauls or a thousand rubber bands woven together to hold it. A good idea is to sharply bevel the edges of the band at the connection point so you can more easily sand it down for a seamless look.
View Loren's profile
10101 posts in 3581 days
#2 posted 11-02-2011 06:20 PM
There’s no best way, but you can get 2” wide pre-glued banding if a thin
1/40” veneer is acceptable to you. That square edge won’t be durable
1/8” to 1/4” thick solid wood banding can be bent on a hot pipe to the
general shape fairly easily, depending on species and tightness of the
radius you need. Clamping the wood to the edge is tricky though – you
can make a ton of your own clamps, use bike tires, surgical tubing, etc.
You can fix a large disk to the top of the table with nails or dowels
around the edge and another similar arrangement underneath, then
use the nails or dowels to anchor your rubber bands, surgical tubes
or bike tires. To some extent masking tape can be used if the
edging is accurately pre-bent. The brown package tape with the
water-activated glue can be used as well.
View DS's profile
2866 posts in 2354 days
#3 posted 11-02-2011 06:44 PM
MDF is most vulnerable to edge impacts.
I would avoid the veneer on the edge as this will afford no protection.
I’ve used the 1/8” solid wood banding as well, but this is problematic to clamp.
Another option is to use a wider band of 3/4” or 1” solid wood (2” Thick) that can be rabitted or biscuit jointed to the edge. This can be cut on a bandsaw in sections to form the edge.
The advantages are that the edge is solid and you can route a nice table profile which will also make the veneer look seamless at the corners.
View tsmccull's profile
10 posts in 2397 days
#4 posted 11-03-2011 02:25 AM
I veneered the top of an old 44” round table with cherry boards about 1/2” thick and ended up with it approximately 1-1/2” thick when I was done. Cut some more cherry about 1/8” thick on the tablesaw for an edge veneer. Sears sells a Craftsman rebranded version of the Wolfcraft one-hand ratcheting band clamp (Amazon and others have it also). That band clamp works very well for applying pressure evenly all around a table in order to clamp fairly thick material for gluing (don’t think I’d try it for true veneer, since it might crush really thin material). 1/8” material for edge veneer was thin enough to bend around the circumference, but thick enough to withstand the pressure of the clamp. It’s been in place for a couple of years and I haven’t seen any delaminating anywhere yet.
View vipond33's profile
1405 posts in 2431 days
#5 posted 11-03-2011 04:51 AM
In our shop we often veneer the edge for looks and ease of application but prior to that we put a 1/8” square piece of solid in a rebate on the top and bottom edge. This goes on easily with tape, is cut back flush and allows for light edge shaping as well as providing impact resistance. For a more durable edge make your veneer strip 2 or 3 ply with a cross band layer.
-- gene@toronto.ontario.canada : dovetail free since '53, critiques always welcome.
View DS's profile
#6 posted 11-03-2011 05:31 PM
Nice solution there Gene, I wouldn’t have thought of that.
I like the idea of having a slightly eased corner too!
This is a great website!
