| Forum topic by GregD | posted 572 days ago | 559 views | 0 times favorited | 9 replies | ![]() |
572 days ago |
Topic tags/keywords: question Any suggestions for flattening the surface of an aluminum bracket? The surface is about 6” long and 2” wide. I would like to be able to take a straightedge to it and not see any slivers of light. The bracket is too large for the sanding disk on my bench top disk/belt sander (6” disk I think). I suspect the belt sander would tend to grind the edges of the part more than the center section. I was thinking about putting PSA sandpaper on my table saw table and try to sand out the imperfections that way. I might have to grind away a 0.002” give or take a factor of 2. Is this likely to work? -- Greg D. -- the price of freedom is tolerance |
9 replies so far
#1 posted 572 days ago |
Yes. A sheet of plate glass may be flatter than your table saw. You |
#2 posted 572 days ago |
Depending on how non-flat your aluminum is, I would do it like you flatten a plane sole. A piece of glass, or other flat surface, some sandpaper, and a spray bottle of water. I would probably start with a 120 grit and work my way up to whatever grit gives you the surface you want. -- Adversity doesn't build character...................it reveals it. |
#3 posted 572 days ago |
+1×2 ^ ... the first like a lapmaster and the 2nd like a plane sole. Either will work and the aluminum will not take forever. You don’t state the gauge of the material, but if very thin (i.e flexible / easily deflected) ) then do not push down too hard or you’ll never get it flat. -- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia |
#4 posted 571 days ago |
do it like you would a plane sole -- When the moderator chooses sides, his site sucks. |
#5 posted 571 days ago |
I have heard of people grinding aluminum with some hard and soft rubber wheels of some sort. I have heard that it is dangerous to grind aluminum on a grinder that you also use to grind steel with because of mixing aluminum with steel particles. It’s a safety hazard. However, I don’t have a lot of experience with machining aluminum because we use mostly steel and cast iron in our machine shop. -- If a man does not keep pace with his companions, perhaps it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away. Henry David Thoreau |
#6 posted 570 days ago |
Thanks for the suggestions. The parts are about 1/4” thick, so I don’t think they will flex significantly. Will window glass work? I know people flatten plane soles doing something like this, but I don’t know the details. Since Sawkerf suggests a spray bottle, do I need to get a particular type of sand paper? I was going to glue down some sandpaper and have at it. -- Greg D. -- the price of freedom is tolerance |
#7 posted 570 days ago |
Use wet and dry sand paper. I wouldn’t think you would need to use 120 if you are only taking off .002”. Maybe though….I am no expert in this area. Wet and dry cuts pretty quickly when you keep it wet. |
#8 posted 570 days ago |
I use a piece of solid surface counter material and wet/dry sandpaper. I spritz the solid surface material to hold the sand paper, then spritz the sandpaper before I start lapping. I use this method to sharpen plane irons and chisels (with finer grits, of course) and have used it with coarser sandpaper to flatten 4-5 plane soles. -- Adversity doesn't build character...................it reveals it. |
#9 posted 569 days ago |
Great. Thanks for the help. -- Greg D. -- the price of freedom is tolerance |
| Forum | Topics |
Woodworking Skill Share
8799 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15818 |
Hand Tools
2040 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
904 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6167 |
