Help- I burned my maple slip feathers
Forum topic by bscur posted 10-31-2011 10:18 PM 1583 views 0 times favorited 8 replies Add to Favorites Watch
View bscur's profile
bscur
17 posts in 2662 days
10-31-2011 10:18 PM
Topic tags/keywords: question box slip feather slipfeather burned maple belt sander
I built some small boxes with maple slip feathers and just burned them. I thought I’d sand them flush using a belt sander and now they are black. The belt was older- should I get a new belt and try again, or do I need to change strategies? Would a new 220 grit belt do it? Ugh. What should I do?
Thanks
8 replies so far
TopamaxSurvivor
18285 posts in 3699 days
#1 posted 11-01-2011 01:31 AM
What are maple slip feathers?
View gfadvm's profile
gfadvm
14940 posts in 2714 days
#2 posted 11-01-2011 04:58 AM
That is another term for miter splines. In answer to the question, I would try a random orbit sander with 120 to 180 grit and see if I could get rid of the burn marks. I would not use a belt sander on maple splines as burning will happen. Ditto for cherry and Jatoba.
View Gene Howe's profile
Gene Howe
10526 posts in 3452 days
#3 posted 11-01-2011 05:05 PM
Wet the wood with vinegar, then use the RO.
View Nomad62's profile
Nomad62
726 posts in 2982 days
#4 posted 11-01-2011 06:38 PM
I would recommend using a card type scraper to remove the burns, then sand to match the rest of the surface.
bscur
#5 posted 11-01-2011 07:09 PM
Thanks for all the advice. I got a new 220 grit belt that worked, but I will try the other methods as well. I should have thought ot the card scraper- I love those.
View rance's profile
rance
4258 posts in 3184 days
#6 posted 11-02-2011 04:49 PM
Sometimes I wish I could get a belt sander with a speed reducer for just such occasions. Next time, not so aggressive on the belt sander, and monitor the temperature of the splines so as to not heat them up. I agree, 220 is not preferred, maybe 120 and go slow.
View shipwright's profile
shipwright
7992 posts in 2821 days
#7 posted 11-02-2011 07:00 PM
Rance, I’m going to get this one before Gene Howe does. Get a ShopSmith ;-) !
rance
#8 posted 11-04-2011 06:20 AM
You are biased. A good answer though. Wish I had the room.
