| Forum topic by KenBry | posted 570 days ago | 1428 views | 0 times favorited | 5 replies | ![]() |
570 days ago |
I have 1 area in my home to do ALL my woodworking. (the garage) Well, I want to create a relitivly dust free area to do my finishing. I need some ideas. I know how a standard clean room works in science. (positive presure filtered air) I think that’s a bit extreme for this particular purpose. Just looking for some solutions others might have come up with, thanks -- Ken, USAF MSgt, Ret. |
5 replies so far
#1 posted 570 days ago |
I also have a garage shop and do most of my finishing right there without much if any special prep. But I don’t do anything in the way of high depth or high gloss where you might notice dust issues more. Generally I cleanup the shop (Utility vac equipped with a ‘HEPA’ filter), then wait at least a few hours, or to the next day for any airborne dust to settle before beginning a finishing project. I also do not to anything in the shop to create dust during the time the finish is wet. Now I certainly won’t say my finishes turn out perfect all the time, but rarely have I noticed a major issue with dust in the finish. I am on a pretty tight budget and considered sectioning off a corner of the garage with plastic sheeting and those zippers you can get that tape in place on the plastic to create a door. You would need to be conscious of the reduced air volume, fumes from finishes will fill up a small space extremely quickly. Venting with a fan and filters may be necessary in addition to normal respirator usage. -- "Anyone who has never made a mistake has never tried anything new." - Albert Einstein |
#2 posted 570 days ago |
Are you spraying or brushing? |
#3 posted 570 days ago |
You can set up a plastic enclosure. Spritzing the air repeatedly with water Clean your shop well, set up the clean room, spritz and vacuum in the |
#4 posted 570 days ago |
Wetting the floor down is a trick I learned in auto body. Keeps the dust on the floor from stirring. |
#5 posted 570 days ago |
What ever else you do it is a good practice to have a wire connected to a solid earth ground. The ground wire of youe electrical system will do fine. The last thing you do before you begin to apply your finish should be to ground your project to remove any static charge that will draw dust. -- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it. |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15797 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
