tenon thickness
Forum topic by Pabs posted 10-31-2011 07:23 PM 1151 views 0 times favorited 5 replies Add to Favorites Watch
View Pabs's profile
Pabs
229 posts in 3323 days
10-31-2011 07:23 PM
hey all
what’s the standard size for a tenon? if using 3/5 stock would the tenon be 1/4 thick?
or should it be thicker than that?
and what is the rule for the depth of the tenon?
thanks
-- Pabs
5 replies so far
View SnowyRiver's profile
SnowyRiver
51453 posts in 3350 days
#1 posted 10-31-2011 07:57 PM
The general rule is 1/3 of the thickness of the stock.
-- Wayne - Plymouth MN
View pintodeluxe's profile
pintodeluxe
5541 posts in 2683 days
#2 posted 10-31-2011 08:15 PM
I go along with the 1/3 the thickness of the tenoned workpiece rule. Unless I am mortising into a thick leg, then I have the freedom to make the tenon a little bigger.
Remember it is not just the size of the tenon that gives a M&T joint its strength, but also the shoulders which help resist racking forces.
View crank49's profile
crank49
4028 posts in 2840 days
#3 posted 10-31-2011 08:43 PM
http://lumberjocks.com/topics/31297
This is a link to the same discussion a couple days ago.
View Pabs's profile
Pabs
#4 posted 11-02-2011 04:06 AM
thanks guys!
-- Pabs
View Pabs's profile
Pabs
#5 posted 11-02-2011 06:58 AM
humm…from what I understand the longer tenon would offer the best glue surface so it would make for stronger joint (in tension at least) but if the joint is being worked side to side then I would think the thicker tenon would be beneficial as it would offer more lateral strength.. .
that would be my guess… .wonder what others have to say about it
-- Pabs
