Durability and grain? Claro Walnut....
Forum topic by KenBry posted 10-31-2011 06:19 PM 1913 views 0 times favorited 3 replies Add to Favorites Watch
View KenBry's profile
KenBry
484 posts in 2475 days
10-31-2011 06:19 PM
I have this real nice Claro walnut that I am going to be using as an end table top. I need to finish it and want to have it durable as well as get the grain to “POP”. I am really unsure what to do with this.
Since I am a total NOOB to finishing fine woods, I had read that using Shelac then Varnish was a nice finish, but I am open to any other ideas.
-- Ken, USAF MSgt, Ret.
3 replies so far
View CharlesNeil's profile
CharlesNeil
2411 posts in 3898 days
#1 posted 11-02-2011 02:31 PM
go with a good oil like Arm R Seal from general finishes, it is a urethane and very durable, it also dries well, you can either use it as a total finish and it will definately “pop”, or let it dry and do a good Waterbourn or other topcoat, Claro can be a little porus, so for me the oil then a good film finish that I can work into the grain and sand back to create a nice level surface is my typical process.,
KenBry
#2 posted 11-03-2011 01:29 AM
Thanks very much, I just read about Arm R Seal somewhere else and was thinking that might work well.
CharlesNeil
#3 posted 11-03-2011 01:47 PM
Enduro Var is an excellent choice, and the Arm R Seal dries fast and the Endurovar can be used over it in 24 hours, so you have your pop and a good durable topcoat,
