Powering digital picture frame at art shows
Forum topic by yellowtruck75 posted 10-31-2011 04:17 PM 1128 views 0 times favorited 2 replies Add to Favorites Watch
View yellowtruck75's profile
yellowtruck75
469 posts in 3089 days
10-31-2011 04:17 PM
I bought a digital picture frame this weekend that I will be using at tshows to display work that I was unable to bring. The issue that I am facing is powering it when there is no power available. Does anyone use battery packs for power during shows? If so what do you use?
2 replies so far
View crank49's profile
crank49
4032 posts in 2993 days
#1 posted 10-31-2011 05:08 PM
That would depend on the picture frame.
Does it have an AC adapter?
What volt output (and amps) is the adapter.
If the adapter says something like 12VDC, 250MA, you could run it off any 12 volt battery with 1/4 amp capacity.
The next trick is to figure out how to connect the battery. You have to determine what the polatiry is. Hooking it up backwards might fry the picture frame’s electronics. And you will need a plug like the one on the adapter.
OR, just take a 12 volt deep cycle, gel cell or AGM type battery (like you would use for a trolling motor) and hook it up to an inverter to get 120VAC. Then you plug in any thing you want; within the inverter’s capacity of course.
View David's profile
David
198 posts in 2686 days
#2 posted 10-31-2011 05:33 PM
Be careful hooking it up to a 12V battery, the actual voltage will likely be higher. If you’re feeling ambitious you could pick up a 7812 voltage regulator (usually good up to 1-1.5A), a little self-adhesive heatsink, and guarantee that you’re getting 12V. The problem is sometimes to save cost the power supply components in small consumer grade electronics are selected such that they won’t tolerate much over their nominal supply voltage. I’ve fried stuff by going only 1V over nominal. Cell voltage for a lead acid cell hot off the charger can approach 2.5V, or 15V for 6 cells in series like your standard 12V lead acid battery.
-- Perilous to all of us are the devices of an art deeper than we ourselves possess. --Gandalf the Grey http://davidwahl.org/category/woodworking/
