Is this a good value bandsaw (Craftsman)?
Forum topic by jimleigh1313 posted 10-31-2011 03:41 PM 12915 views 0 times favorited 9 replies Add to Favorites Watch
View jimleigh1313's profile
jimleigh1313
62 posts in 2408 days
10-31-2011 03:41 PM
Topic tags/keywords: bandsaw band saw craftsman 11324201
http://nashville.craigslist.org/tls/2676820471.html
“for sale a 12” craftsman stand up bandsaw does need a saw blade other than that it is in perfect working order stands about 4.5 feet tall”
My first post!
I’m just getting in to woodworking, but I want good quality, mostly used, equipment due to budget constraints. Is this bandsaw listed in my local craigslist a good value? I think it needs an 80” blade which looks pretty inexpensive. I want a general purpose saw that can do most things that I could ask of it. Its a Craftsman Band Saw/Sander. The model # is 11324201, but I can’t find anything on the web except parts ordering. Probably won’t be using the ‘sander’ part because Sears no longer sells the 80” sanding strips. Thanks guys!
- Jim
9 replies so far
View Charles Maxwell's profile
Charles Maxwell
1099 posts in 3806 days
#1 posted 10-31-2011 04:12 PM
I bought this same saw in 1988…the original bulb still works! Nuff said! By the way, you’ll want to invest in good quality blades and, if you intend to cut 6” (or greater) thick pieces without blade drift, recommend 3 or 4 TPI 3/8” blades with a good tension on the blade! You can get said blades from your local WoodCraft.
-- Max the "night janitor" at www.hardwoodclocks.com
117091 posts in 3576 days
#2 posted 10-31-2011 05:09 PM
I avoid craftsman tools but it’s almost impossible to get a working band saw for $75.
View crank49's profile
crank49
4030 posts in 2969 days
#3 posted 10-31-2011 05:16 PM
I see those same bandsaws on the Nashville CL all the time. Usually about $75 to $100. They must have made a bunch of them.
I think you can get a Wood Slicer 1/2” re-saw blade to fit that saw from Highland Woodworking. They make one for my little 10” Rikon and it’s great.
View DaddyZ's profile
DaddyZ
2475 posts in 3039 days
#4 posted 10-31-2011 05:18 PM
You might hold out for a better deal, I found a 14” HF Central MAchinery w/ 4 New(Still Shrinkwrapped)blades for $165, Didn’t even look like they used the saw.
View TheDane's profile
TheDane
5423 posts in 3662 days
#5 posted 10-31-2011 05:36 PM
I see these on our local CL quite often … sometimes as low as $50. I looked at one a few years ago before I bought my Jet … the guy was a deer hunter and had been using to cut meat! And, NO, I didn’t buy it.
—Gerry
jimleigh1313
#6 posted 10-31-2011 05:40 PM
Thanks for the replies so far guys! Another question I thought of…Are there any features or conveniences that would come standard on a newer saw that wouldn’t necessarily be on a saw such as the one shown above? (20 years or so)
TheDane
#7 posted 10-31-2011 05:55 PM
A saw with a tension release lever should be high on the list. I retro’d my saw with a Carter and it is a God-send when changing blades.
I would also look for a 1hp or greater motor, and the ability to install a riser bock to increase cutting capacity.
Mobile bases are nice … I bought a Jet 708115K JWBS-14CS. I like the closed stand (I put it on a Shop Fox mobile base and put a plywood floor in it for blade an accessory storage).
—Gerry
TheDane
#8 posted 10-31-2011 06:03 PM
Also … regardless of which saw you buy, outfit it with quality blades.
You’d be surprised how much of a difference a decent blade can make, even when you have a lower quality saw.
I had a Craftsman before the Jet landed, and had all kinds of problems with it until I started using better quality blades. The guy I sold it to busted the 1/4” blade trying to cut a board with a nail in it, so he bought one of the blades off the rack at Menards … had a hell of time getting it to track.
For re-sawing, I am a Highland WoodSlicer fan. For general cutting, I like Carter AccuRight blades. They cost a bit more than the ones you pick up at the BORG, but the performance improvement (IMHO) is worth it.
—Gerry
View Randy Sharp's profile
Randy Sharp
363 posts in 3671 days
#9 posted 10-31-2011 06:05 PM
Jim,
I bought this machine, used. I replaced the tires and blade guide bearings, and unhooked the sanding pulley. It has served me well and is perfect for the weekend warrior.
Like a1Jim, I try to avoid Craftsman. But this product at that price seems a fair deal to me. In short, if I had the choice to do it again, I would.
Hope my opinion is helpful!
-- Randy, Tupelo, MS ~ A man who honors his wife will have children who honor their father.
