Hinge mortiseing jig
Forum topic by Guss posted 10-30-2011 04:31 AM 7209 views 1 time favorited 16 replies Add to Favorites Watch
View Guss's profile
Guss
94 posts in 2435 days
10-30-2011 04:31 AM
Hi I was woundering if any one knew of a good hinge mortising jig for a router that can handle multiple sizes
16 replies so far
View devann's profile
devann
2246 posts in 2686 days
#1 posted 10-30-2011 04:41 AM
I have a Porter Cable that I’ve used for years. It does mulitple sizes and square and round corner hinges. Was around $20. If you have lots of doors to do Porter Cable makes a nicer model but it’ll set you back more $$$
View Pete_Jud's profile
Pete_Jud
424 posts in 3747 days
#2 posted 10-30-2011 05:26 AM
It’s easy to make your own as well. But the Porter Cable works well, and is fairly cheap.
-- Life is to short to own an ugly boat.
View Guss's profile
Guss
#3 posted 10-31-2011 05:34 AM
does anyone have plans to make one?
View doordude's profile
doordude
1085 posts in 2977 days
#4 posted 10-31-2011 06:24 AM
I don’t know for what type of hinge; but if its for doors; as in house doors then you can find a good repeatable jig at
“Norfield tool.com” they are in chico,ca,tools for prehang door companies
View rance's profile
rance
4258 posts in 3154 days
#5 posted 10-31-2011 06:26 AM
Look at the Mortise Pal. A bit expensive but a good store bought jig I suspect. It is completely adjustable.
View richgreer's profile
richgreer
4541 posts in 3068 days
#6 posted 10-31-2011 03:35 PM
I own a Mortise Pal and like it very much, but it would not work for making door hinge mortises.
I always make my own jig for hinge mortises. It’s very easy to do and I see no need for any plans to make them.
I use a simple piece of plywood and make two cuts in from the side with a band saw. The distance between the outside of the cuts is according to this formula –
Distance between the outside of the cuts = H+BU-BI
where H = width of hinge BI = Diameter of bit BU = diameter of bushing
I usually use a 3/8” bit and a 1/2” bushing.
I make the cuts a little deeper than I think I will need and then make a cut across the ends to form a square.
I set the hinge in place and place the plywood in place such that the gap on all 3 sides is equal to 1/2 of BU-BI and I make a pencil mark on the back underside along the edge of the door.
I then clamp a 2×2 on the underside of the plywood along that edge and screw it to the plywood from the top. Keep the screw heads away from where your router base will be.
Then clamp the 2×2 to the door at each end and cut your mortise.
I can make one of these in less than 5 minutes. I usually don’t keep the jig for future projects because I can make another very easily.
Note 1 – Sometimes, I don’t bother with the 2×2. I just screw the plywood directly into the edge of the door temporarily. No one will notice those screw holes (especially if I fill them with wood filler).
Note 2 – If the hinge has square corners, finish the corners with a chisel.
View Guss's profile
Guss
#7 posted 11-01-2011 03:23 AM
I am making boxes and making my own wooden hinges and they vary in size for every project so something adjustable would be nice I saw the video for this one that is a homemade http://www.shopnotes.com/issues/74/videos/using-the-hinge-mortising-jig/ but i couldn’t find the plans here is one that rockler sells but it seems a bit pricy http://www.rockler.com/product.cfm?page=2290
devann
#8 posted 11-01-2011 06:16 AM
Guss, Making your own jig is not that hard. I mentioned the Porter Cable because it comes with a nifty router bit that will cut a sqaure corner, no chisel required when used with the adjustable jig. Comes in handy when you’re doing the larger commercial doors hinges. I think that you can buy the PC router bit alone as a replacement bit.
View Guss's profile
Guss
#9 posted 11-02-2011 03:01 AM
is this the one you are talking about on the right http://www.door.cc/How-To-Hang-A-Door.html. how small of hinges will the porter cable do?
devann
#10 posted 11-04-2011 05:58 AM
the model 59370 is the one I’m using these days. A 3” hinge is as small as it’ll do.
View Critter's profile
Critter
3 posts in 2380 days
#11 posted 11-16-2011 04:33 AM
Not sure if it is what you are looking for, but if you want to build one yourself, I have a set of plans that I could send you. critter2722@yahoo.com
-- "Primum non nocere"-- Hippocrates
View Guss's profile
Guss
#12 posted 11-16-2011 04:44 AM
ya ill take a look at it
View Richard's profile
Richard
1916 posts in 2684 days
#13 posted 11-17-2011 11:01 PM
Woodsmith mag has a pretty neat one that you can get free plans for from here. You just have to signup for thier weekly tips in your e-mail to acces them, and there is no charge to sign .
http://www.woodsmithshop.com/episodes/season4/409/
View Fuzzy's profile
Fuzzy
298 posts in 3982 days
#14 posted 11-17-2011 11:36 PM
+1 on the WOODSMITH jig … I built one and use it with a BOSCH COLT … it is dead on accurate.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
13603 posts in 3335 days
#15 posted 11-18-2011 12:14 AM
i have used most commercial jigs
and although they are good
they cost to much for me
so i make my own
http://lumberjocks.com/patron/blog/22313
