Danish Oil on plywood
Forum topic by DHaden posted 10-29-2011 06:22 PM 9679 views 0 times favorited 6 replies Add to Favorites Watch
View DHaden's profile
77 posts in 2592 days
10-29-2011 06:22 PM
I am building a dresser top valet, using walnut frame with birch plywood shelves. I will finish the walnut with Danish Oil. My question is can I use DO on the ply, or will it cause it to delaminate? If this is a problem any ideas?
-- Measure once, cut twice.
View Bill White's profile
Bill White
4878 posts in 3894 days
#1 posted 10-29-2011 08:23 PM
I would use a wiping varnish or water based semigloss poly on the ply.
View ETwoodworks's profile
92 posts in 2627 days
#2 posted 10-29-2011 08:28 PM
I have used danish oil on oak ply without any problems but maybe i got lucky. I have only done it a few times and I am no expert.
-- Building quality in a throw away world.
#3 posted 10-29-2011 09:38 PM
Thanks, I think I will give it a shot and see what happens.
View DaleM's profile
958 posts in 3317 days
#4 posted 10-29-2011 10:09 PM
I have used Watco Danish Oil on cherry, oak, maple and birch plywood with absolutely no delamination. The cherry and birch sometimes have darker blotches but no other problems. The only delamination problems I have had with ply were a couple of times with water-based latex paints for some reason. It would obviously separate and have a raised area when wet and expanded somewhat with the water, then lay back down somewhat when dry, possibly just a bad glue-up at the factory.
-- Dale Manning, Carthage, NY
10101 posts in 3581 days
#5 posted 10-29-2011 10:46 PM
It works fine on birch ply. I have used it. It does take awhile to cure, so
avoid putting on the inside of a cabinet and closing the door – the stuff
needs air circulation to dry.
I’d go with the natural oil on the ply. Staining oils look real ugly on birch
ply in my opinion.
View pmayer's profile
1022 posts in 2999 days
#6 posted 10-30-2011 07:01 PM
I’ve also used it on all sorts of ply with no delamination.
-- PaulMayer,
