Is This A Dumb Idea?
« back to Hand Tools forum
Forum topic by gfadvm posted 10-29-2011 04:02 AM 1358 views 0 times favorited 11 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
14940 posts in 2597 days
10-29-2011 04:02 AM
Topic tags/keywords: flattening soles
Could I use my 4×36 stationary belt sander to flatten the soles on hand planes? This just seems too quick and easy vs. rubbing it on sandpaper for hours. Anyone tried this?
11 replies so far
View jumbojack's profile
jumbojack
1673 posts in 2531 days
#1 posted 10-29-2011 04:22 AM
I would give it a try on a junk plane. i would think a pretty high grit to start.
View Arlin Eastman's profile
Arlin Eastman
4095 posts in 2468 days
#2 posted 10-29-2011 04:34 AM
I do not think I would, I have heard of to many of the plenums are not good enough for that kind of flat work.
You could as Bertha and he would know for sure.
Arlin
-- Please help me help other Vets click..> http://www.gofundme.com/m1abko.....It is always the right time, to do the right thing.
View DaleM's profile
DaleM
958 posts in 3291 days
#3 posted 10-29-2011 04:55 AM
I’ve done it on one plane because it was in such bad shape. It was never flat to begin with from the looks of it. It is a Great Neck Corsair number four sized. I just was careful not to let it heat up much and it worked okay for me. I know unequal heating of cast iron can causing cracking so maybe I just got lucky. I have a large piece of granite that I got free from a local stone cutter and use to flatten my other planes, but wasn’t going to spend all day on a cheap plane. I started to flatten the sides and square them to the sole too, but they were so far out of whack that I gave up on that idea. I guess I’ll never use this one with a shooting board. Bottom line; if it’s a cheap plane that you can live without just in case it cracks, then I say go for it and save some time for something else.
-- Dale Manning, Carthage, NY
16272 posts in 4125 days
#4 posted 10-29-2011 05:17 AM
I’ve done it several times on planes that were in bad shape. I always go back to my sandpaper-on-granite method for the final flattening, but the belt sander seems to work well as a starting point.
Having said that, I wouldn’t do it with a newer, expensive plane. I’m just talking about rustbucket refurbs.
View rance's profile
rance
4256 posts in 3067 days
#5 posted 10-29-2011 05:33 AM
Yes, it can be done. That’s not to say anyone could do it successfully. You don’t want to get it out of square with the side of the plane so don’t be too aggressive. As has been suggested, your sander may not be perfectly flat. Test yours with some stable wood, then check the wood for flatness immediately. Start with higher grits and keep it moving in a circular pattern so as to minimize any problems with sander transferring to the wood/your plane.
No, I’ve not done it but I know of folks who have. It can be accomplished.
gfadvm
#6 posted 10-30-2011 04:39 AM
Sounds like the consensus is do it by hand. Thanks for the input.
Craftsman on the lake
2741 posts in 3345 days
#7 posted 10-30-2011 04:52 AM
I have a 6×48 belt sander and it really doesn’t even put a flat surface on wood. The belts all have a slight flutter to them so I doubt if it would work for the absolute flatness needed for a plane.
View Brandon's profile
Brandon
4152 posts in 2858 days
#8 posted 10-30-2011 05:09 AM
I have a Ryobi 4×36 belt sander. I had a cheap plane (stamped steel frog, etc.) and thought I’d try to flatten its sole on the belt sander, but it didn’t work at all and was uneven. I would not recommend it. :-)
-- "hold fast to that which is good"
View PurpLev's profile
PurpLev
8534 posts in 3555 days
#9 posted 10-30-2011 05:11 AM
you can do that to really rusty/out of shape planes in order to clean them up and knock off high spots quickly, but not as a substitute to the sand paper on flat surface as the belt sanders do not have a flat reference to begin with and cannot produce anything that is truly flat. it can however speed up the process before you lap the soles on a sand paper.
View docholladay's profile
docholladay
1287 posts in 2966 days
#10 posted 10-30-2011 05:15 AM
I’ve done it before. You can do it for the initial flattening, but still need to do some further lapping with finer grades of paper, but the intitial flattening goes much quicker.
Doc
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View drfunk's profile
drfunk
223 posts in 2584 days
#11 posted 10-30-2011 05:26 AM
I personally don’t lap my soles. Did it on a few planes (granite + sandpaper) – not sure it makes enough of a difference to be worth the effort for me – I’d rather refine my technique to the idiosyncrasies of the plane. Did old-timers lap soles or is this a new thing?
