Table Tops
Forum topic by Eugene posted 10-29-2011 02:16 AM 1339 views 0 times favorited 8 replies Add to Favorites Watch
View Eugene's profile
Eugene
31 posts in 3650 days
10-29-2011 02:16 AM
Topic tags/keywords: question
What is the best way to secure a table top to the legs and apron?
-- Eugene, North Carolina, slimderx@yahoo.com
8 replies so far
View paratrooper34's profile
paratrooper34
915 posts in 2920 days
#1 posted 10-29-2011 02:37 AM
Eugene, I like to have a 1/4” (or so) dado running the length of the inside of the apron that I can then make (or buy) clips to slide into the dado and then screw the top down from those those clips. I have also fabricated corner pieces that sat flush to the top of the legs and apron and then anchor the top through those. Hope that helps.
-- Mike
View oluf's profile
oluf
260 posts in 3007 days
#2 posted 10-29-2011 02:48 AM
rabit the apron and use metal or wooden ofset blocks screwed into the bottom of the table top.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
16274 posts in 4186 days
#3 posted 10-29-2011 02:50 AM
Yep…. I use these. They fit nicely into a saw kerf.
http://www.rockler.com/product.cfm?page=784
View Jonathan's profile
Jonathan
2608 posts in 3018 days
#4 posted 10-29-2011 03:27 AM
Attach s-clips, or table clips to the apron (like the ones in the link that Charlie posted above), if you don’t want to make your own. 1/8” saw kerf (as mentioned) should fit nicely for the pre-made clips. Obviously if you make your own (like paratrooper34), you can make the dado whatever size you want to fit the block into, allowing it to slide/move as the wood for the top expands and contracts.
You can attach the apron to the legs with corner brackets and/or pocket screws if you have a pocket hole jig. If you want to make it solid, use the pocket screws and corner brackets in combination to attach the apron to the legs.
I think oluf meant to say dado the apron, not rabbet it?
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
Rick Dennington
5808 posts in 3162 days
#5 posted 10-29-2011 06:52 AM
I use “figure 8’s” to attach all my table tops. Easy to install…..no glue, and good wood movemnet, yet strong. Take a look at my project “Shaker Hall table” in my projects page, and you’ll see how it’s done….piece of cake…..
View Les 's profile
Les
201 posts in 2658 days
#6 posted 10-29-2011 01:57 PM
+ 1 for what Charlie said
-- Stay busy....Stay young
View Sawkerf's profile
Sawkerf
1730 posts in 3036 days
#7 posted 10-29-2011 03:31 PM
I use figure eights for all of the reasons Rick gave.
Jonathan
#8 posted 10-29-2011 03:47 PM
Eugene, Sorry for the confusion. I meant to type z-clips, or z-fasteners (not s-clips…didn’t mean to lead you astray). I was checking LumberJocks at work again, with distractions when I originally posted.
Here’s an article discussing various ways to attach tabletops, with some good illustrations as well.
