Threaded inserts, I been doing it wrong all along
Forum topic by patcollins posted 10-28-2011 02:21 PM 118017 views 7 times favorited 36 replies Add to Favorites Watch
View patcollins's profile
patcollins
1687 posts in 3063 days
10-28-2011 02:21 PM
I have been installing them backwards, I have even seen a tool made for using them backwards too.
Watch this video here
36 replies so far
View harshest's profile
harshest
63 posts in 2602 days
#1 posted 10-28-2011 02:44 PM
As a beginner woodworker that was a very informative video, thanks.
View Gregn's profile
Gregn
1642 posts in 3181 days
#2 posted 10-28-2011 02:55 PM
Thanks for clarifying the purpose of the slots on the inserts. It makes more sense than than a screwdriver slot.
View NiteWalker's profile
NiteWalker
2738 posts in 2774 days
#3 posted 10-28-2011 03:11 PM
I install mine using the drill press method. I don’t bother with the wrench though.
A couple of things I also do is chamfer the edge of the hole with a countersink for a cleaner install. Since threaded inserts work best a bit below the surface of the wood I use a steel bushing between the two nuts and the threaded insert. It’s sized for the machine screw but the outside diameter is the same as the hole that the threaded inserts go into. I’m able to sink the inserts a bit below the surface without marring the workpiece. I got the steel bushing (under spacers) from mcmaster carr. I use and like the EZ-Lok inserts. Great quality.
Here’s a pic of how mine come out.
View steviep's profile
steviep
233 posts in 2844 days
#4 posted 10-28-2011 03:20 PM
Great find, Pat. Just another thing thing I have doing wrong for years!
-- StevieP ~ Micheal Tompkins - you were not here on earth long but left a giant mark on us. RIP Brother
patcollins
#5 posted 10-28-2011 03:34 PM
I can’t begin to count the number of ones I broke using that as a screwdriver slot when I first started using them. In fact I almost bought this
View jusfine's profile
jusfine
2422 posts in 3123 days
#6 posted 10-28-2011 04:27 PM
I have always used the hex drive inserts from Lee Valley, harder to make a mistake there… :)
Thanks for the tip!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View richgreer's profile
richgreer
4541 posts in 3272 days
#7 posted 10-28-2011 04:35 PM
I have a special tool that I use with the slot to insert these and I have had occasional problems with the insert not lining up properly.
I had never thought of this method, but this is what I will use from now on.
16280 posts in 4416 days
#8 posted 10-28-2011 04:52 PM
Well I’m going to admit that the way this guy demonstrates is an excellent method.
However, he is full of #$%& when he says that those slots are to help cut the threads. Those are in fact screwdriver slots, but they are best used not with a screwdriver, but with one of these:
View derosa's profile
derosa
1577 posts in 3033 days
#9 posted 10-28-2011 04:55 PM
I was wondering about the accuracy of that as the last ones I used had a allen wrench insert on the same side as the slot which is what I used to install mine.
-- --Rev. Russ in NY-- A posse ad esse
patcollins
#10 posted 10-28-2011 09:27 PM
Charlie, have you ever tried to use a screwdrive to install a threaded insert? The slot is alot wider than any screw driver that I have seen, thats why I kept breaking them.
View Roger Clark aka Rex's profile
Roger Clark aka Rex
6940 posts in 3632 days
#11 posted 10-28-2011 09:55 PM
Not being a seasoned WW, I have often wondered why the outer “thread/cutter” is not a left handed thread. If both threads are right handed, doesn’t that pose a situation where, let’s say a bolt gets “stuck fast” in the threaded insert, would attempts at extraction tend to extract the insert too?
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
#12 posted 10-29-2011 05:24 AM
Pat, a really large screwdriver fits most inserts I’ve used pretty well, but it is easy to misalign them.
View Kjuly's profile
Kjuly
311 posts in 3483 days
#13 posted 10-30-2011 05:04 PM
Hello Pat,
I have been using threaded inserts for years and have a love/hate relationship with them. Lately I used them only as a last resort. After viewing the video, I went out to the shop and tried the drill press method. It worked 10 out of 10 times.
Thanks for sharing.
Keith
-- Keith, Charlotte, MI www.julyswoodworks.com
View darryl's profile
darryl
1795 posts in 4524 days
#14 posted 10-31-2011 06:16 AM
well imagine that… all those wine bottle stoppers i made with threaded inserts, mine are in backwards too!
View Dusty56's profile
Dusty56
11822 posts in 3885 days
#15 posted 05-04-2012 01:46 AM
I guess someone needs to tell WoodCraft that they don’t know what they’re talking about !
I wonder what brand of insert that guy is using in the video ? They look different from the ones I’ve used in the past.
showing 1 through 15 of 36 replies
