Lathe tool sharpening
Forum topic by D_Allen posted 10-28-2011 03:41 AM 3030 views 1 time favorited 1 reply Add to Favorites Watch
View D_Allen's profile
495 posts in 2717 days
10-28-2011 03:41 AM
OK, here it is…but keep the laughter to a low roar!
I knew I was going to have to sharpen the tools. All of the reading about turning lead to the fact.
So, it is good that I had this cheap HF set to practice with.
I’m not very good at freehand sharpening, but I can make things that will help with the task.
The first picture is my conversion of a bench grinder to a slow speed grinder. It runs at about 950 rpm.
The second image is an adjustable toolrest with a miter bar slot. I then constructed a holder for the 1” skew.
This is the edge on one side after sharpening.
This is how it looked before when I tried to freehand it….not too good and it was not straight across prior to the other side being sharpened.
I always like to prototype these things to see what works. Now I will make a block for the other end of the gray aluminum plate for the other side and opposite angle. This should also work for the 1/2” skew.
Got questions…bring em on!
-- Website is finally up and
1 reply so far
View PurpLev's profile
8534 posts in 3581 days
#1 posted 10-28-2011 03:48 AM
very cool setup – I think it’ll work great for you in the long run. some things are fine freehand, but others require a consistent and straight line like you’ve noticed.
