Round over bits
« back to Hand Tools forum
Forum topic by bmwrider1 posted 10-27-2011 06:50 PM 2015 views 0 times favorited 8 replies Add to Favorites Watch
View bmwrider1's profile
bmwrider1
15 posts in 2732 days
10-27-2011 06:50 PM
Will someone explain to me about round over bits? When do I use a 1/4 or 1/2 inch round over bit. I am exploring how to use a router.
8 replies so far
View David Grimes's profile
David Grimes
2078 posts in 2880 days
#1 posted 10-27-2011 07:03 PM
The roundover bits will all have the cut radius and cut depth noted on the package. The 1/4” cut radius (like a quarter round of a 1/2” diameter circle) is a smaller roundover than the 1/2” (which is like a quarter round of a 1” diameter circle). The cut depth is the height of the radiused cut on your work piece edge.
Go to a big box and compare the two drawings of the exact cut profile shown on the box and you’ll get it.
Have some fun.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View ksSlim's profile
ksSlim
1290 posts in 3130 days
#2 posted 10-27-2011 07:14 PM
Grab a piece of stock, gives you 4 edges to try different sizes full depth.
Hang it on the wall as a reminder of what size does what profile.
-- Sawdust and shavings are therapeutic
16281 posts in 4459 days
#3 posted 10-27-2011 07:31 PM
What David said. Or just go to any of the major woodworking catalogs… they pretty much all have profile diagrams.
Keep in mind that you can also vary the look of your cut by varying the depth. You can either have a perfectly rounded edge, or set the cut a little deeper and leave a lip.
The best way to learn is by actually making some cuts and playing with the settings.
View gfadvm's profile
gfadvm
14940 posts in 2931 days
#4 posted 10-28-2011 04:07 AM
Those 2 bits can also be used to make your own 1/2” and 1” dowels useing a router table. The Grizzly catalog has pages of router bits and the profiles they produce. FYI roundover bits are not hand tools. You might get more replys in the power tool forum.
View ocwoodworker's profile
ocwoodworker
209 posts in 3245 days
#5 posted 10-28-2011 04:43 AM
Or are you talking about the shank? A smaller 1/4” shank is good when you have a small round-over bits. When you start to get into some beefy round-overs ( or any bit that has an overall profile bigger than 1/2” is my rule of thumb) it’s better to step up to a 1/2” collet. It has less vibration which in turn give a cleaner cut.
-- I'd like to believe Murphy's Law haunts my woodshop, because if it's Karma it would mean I had something to do with it. - K.R.
bmwrider1
#6 posted 10-28-2011 05:23 AM
I have not bought any bits at this time so I am thinking the 1/2 will be the first one. Are the Whiteside bits a good purchase? I will get the 1/2 inch shank.
David Grimes
#7 posted 10-28-2011 06:07 AM
All well and good, but the 1/4 shank might be the better first bit if you have a small router to run it. Cheaper, less mass, etc. Make sure the collet is tight. If you’ve ever launched one, you’ll be sure from then on.
ocwoodworker
#8 posted 10-28-2011 06:06 PM
Whiteside are made in the US. Good purchase. MLCS… stay away from! The cheap price is enticing but they are china crap. They dull after a couple of passes and are mostly out of balance which causes the router to vibrate and make it hard to control. Rockler makes ok bits but made in Tiawan. They are made to US quality. Just not made in the US.
