Mortise and tenon rule of thumb?
Forum topic by KenBry posted 10-27-2011 03:28 PM 13080 views 0 times favorited 6 replies Add to Favorites Watch
View KenBry's profile
KenBry
481 posts in 2355 days
10-27-2011 03:28 PM
I am getting ready to create several mortise and tenon joints. I was wondering if there was a “rule of thumb” when cutting these.
So for inctence my 4.5” rails are going across a 20” distance into 2” square legs. The rails are 3/4” thick. The question is what should my tenon dimensions be? I know once I have my tenon dimensions I can cut my mortise first then cut my tenons to fit tight. I also know I need extra material on the ends to allow for the tenons just not sure how much I should have.
-- Ken, USAF MSgt, Ret.
View crank49's profile
crank49
4029 posts in 2879 days
#1 posted 10-27-2011 04:02 PM
Most rules or reccomendations I have seen suggest 1/3 the stock thickness. So, for 3/4” stock that would be 1/4”. I agree with that and thats what I use for 3/4” into another 3/4” piece. In your situation, 3/4” into 2” stock, I would make my Tennon 3/8” or maybe even 1/2” if it needed extra strength; like for a long rail.
I try to make the length of my tennons 2 times their width. So, if you go 3/8” tennon, they would be 3/4” long. Again, this can change depending on the application. Like for pinned tennons, they have to be longer.
Note that if you have 1/2” tennons on two sides of a 2” leg and make them both 1” long, the ends will have to be mitered.
View Rick  Dennington's profile (online now)
Rick Dennington
5698 posts in 3102 days
#2 posted 10-27-2011 06:06 PM
I agree with crank49 on his explanation of what needs to be done to mortise and tenons…..That’s pretty much how I do all of mine with the stock you mentioned. Most of the time when I work with 3/4” stock, I normally do the 1/4” mortise and tenons…...One thing I’ve found….when I make the tenons 1” long, I usually have to shave them back to about 7/8”,or a shade shorter to keep them from hitting each other… Sorry…I see that crank has already explaned that…..:)
View Loren's profile
9971 posts in 3556 days
#3 posted 10-27-2011 06:39 PM
1/2 to 1/3 the stock thickness.
KenBry
#4 posted 10-28-2011 04:47 AM
Thanks for the help folks. Based off the recomendations I am going to make my tenons 3/4” long and 3/8” wide. For this project.
View RGtools's profile
RGtools
3372 posts in 2562 days
#5 posted 10-28-2011 09:06 PM
I know this is a late entry and I agree with all of the above but would like to add:
The rule I use is to equalize the strength of the two peices. On 3/4 stock a good tenon width is 1/4, length 1 and 1/4 long if you can make that happen….but this is a rule for joining equal width peices. If you are joining a 3/4 peice of material into the face of some stock 3 inches wide, making the tenon thicker will increase the overal strength of the joint.
You should also factor in how you cut your mortise (for me, what size chisel I have on hand) and match your width to the closest tool you have on hand. I also factor the strength of the woods being joined, if I am putting hickory into poplar for instance, the tenon can be slimmer to equalize the strength of the peice.
-- Make furniture that lasts as long as the tree - Ryan
Rick Dennington
#6 posted 10-28-2011 09:11 PM
RGtools….....I’ll buy that for a dollar…..
