Just another tree in need of ID
Forum topic by topcat posted 575 days ago 907 views 0 times favorited 21 replies Add to Favorites Watch
View topcat's profile
topcat
43 posts in 600 days
575 days ago
Topic tags/keywords: question
Hi all, I am in need of help I found these logs;
From Unknown tree 1
From Unknown tree 1
it has really cool growth rings. Kinda hard to tell, but the heartwood is a deep brown, interspersed with a light brown and sapwood is a creamy white. It resembles Walnut when resawn. I am making a couple of boxes and it would be nice to tell potential customers what specie the wood is. If anyone has any suggestions, I really appreciate them.
-- Tom - As you get older, you learn to hide your mistakes better
21 replies so far
View ShaneA's profile
ShaneA
3972 posts in 770 days
#1 posted 575 days ago
I will throw the first guess out there. To me, it looks like Elm.
View Jeff in Huntersville's profile
363 posts in 1366 days
#2 posted 575 days ago
My guess is black walnut. The very light sapwood and dark inner wood are typical. The bark looks similar too. Were there any leaves laying around where you found the logs? Do you have access to them? It would help with identification.
topcat
#3 posted 574 days ago
Jeff, I don’t have direct access to the leaves. It is growing in a cemetary by my house, so I suppose I could find it, but I did cut a thin piece from the log to show the grain. I put a little Danish oil to accentuate the grain;
From Unknown tree 1
View Joe Lyddon's profile
Joe Lyddon
6397 posts in 2224 days
#4 posted 574 days ago
That looks like walnut to me…
View yrob's profile
yrob
265 posts in 1824 days
#5 posted 574 days ago
I am pretty sure its black walnut.
-- Yves
View WDHLT15's profile
WDHLT15
687 posts in 648 days
#6 posted 573 days ago
It is not black walnut. The bark is not dark and furrowed, the inner bark in not yellow, and the heartwood is not chocolate brown. The heartwood of the board in the pic is more of a dark-yellowish brown with a pronounced ray fleck. Looks like mulberry.
-- Wood-Mizer LT15
topcat
#7 posted 573 days ago
WDHLT15, you’re right about the fleck. The edge grain seems to resemble some edge grain I’ve seen on Maple boards, albeit a different color.
ShaneA
#8 posted 573 days ago
Ok, I have an elm tree in my back yard. Stick factory of a tree, but that is a story for another day. Had to saw up a branch on it today. No doubt, to me, your pic is elm. The large spaced growth rings, the color of heart/sap, the bark all are same as pics. Pretty confident on this one.
WDHLT15
#9 posted 571 days ago
If is elm, then the latewood pores will be arranged in very distinct wavy bands. I did not see that in the pic, but that does not mean that they are not there. Can you take a little closer shot of the growth rings/end grain?
-- Wood-Mizer LT15
View Mikeyf56's profile
Mikeyf56
171 posts in 1393 days
#10 posted 571 days ago
Looks like hickory to me.
-- Powered by Smith & Wilson~~~
WDHLT15
#11 posted 570 days ago
At this point, I would not argue against hickory either. A close up of the end grain will likely solve this mystery.
-- Wood-Mizer LT15
topcat
#12 posted 570 days ago
Wow, it’s like having the tree detectives on your side . . . thanks for the input, guys. Here’s a few more shots. Same wood, different log; sanded to 120;
From Unknown tree 1
From Unknown tree 1
From Unknown tree 1
I tried 3 different settings on the camera. #1 and #3 are closest to life color under a fluorescent light.
Joe Lyddon
#13 posted 570 days ago
It don’t look like walnut to me…
Looks like a fast growing tree…
WDHLT15
#14 posted 570 days ago
OK! So it is definitely not elm as the latewood pores are not arranged in wavy bands. It is not an oak because it does not have the large medullary rays (the feature that gives quartersawn oak that beautiful ray fleck). I am almost positive that what you have is black locust, Robinia pseudoacacia.
Black locust only ever has a narrow sapwood band, usually only a couple of growth rings wide. The wood is ring porous with large earlywood pores and small latewood pores like oak, hickory, and ash. The pores should be occluded with tyloses which are white crystalline structures that clog up the pores (this is why white oak is used for wine and whiskey barrels as the tyloses impede water movement. Red oak does not have these structures). That appears to be the case in the pics. The wood should be dense and heavy. Black locust is a member of the pea family, the fruit is a pod, and the leaves are bi-pinnate compound, which is rather unusual for native trees. The flowers are pea shaped, white or lavender, and showy. The wood is one of the most rot resistant native american hardwoods. Black locust posts last for decades in the ground.
This should make some especially nice boxes indeed!
-- Wood-Mizer LT15
WDHLT15
#15 posted 569 days ago
Black locust has stipular thorns, a pair at the base of each bud on the twig, just like the thorns on a rose bush. Honeylocust has thorns that are modified branches. They are dangerous, long, and the thorns branch making them formidable weapons. They occur anywhere on the trunk or branches, not just associated with a bud. Leaves on black locust are compound and are divided once (pinnate compound) while the leaves on honeylocust are compound and are divided twice (bi-pinnate compound). The bark of honeylocust is generally smoother than that of black locust. Both are legumes and have pea-like pods. The wood of black locust of yellowish brown while that of honeylocust is more of an yellowish reddish orange. The pores of honeylocust are not typically fully occluded with tyloses as they are in black locust. Also, honeylocust is not as rot resistant as black locust.
-- Wood-Mizer LT15
