Affixing to metal studs
Forum topic by garriv777 posted 570 days ago 935 views 0 times favorited 12 replies Add to Favorites Watch
View garriv777's profile
garriv777
87 posts in 1030 days
570 days ago
Forgive me for what may seem like a dumb question but what are most of you guys using for putting up shelves and so on when the studs are metal? The regular drywall screws don’t seem to work well in metal studs and I know that a lot of people use toggle bolts for heavy things like hanging t.v.s and such but I just don’t really like those, you have to drill such big holes for the toggle. Any help would be appreciated. I haven’t ever lived in a place where all my walls had metal studs so I haven’t had to deal with this problem. Thanks in advance
Gary
12 replies so far
View 000's profile
000
3352 posts in 782 days
#1 posted 570 days ago
That’s a good one. I suppose you may have to use Toggle bolts as you said.
Every solution I can think of requires you open the wall and install real lumber or some kind of angle bracket to the metal stud that will hold a self tapping screw more firmly.
Maybe you should just bite the bullet and rill a big hole.
However – - – -use a brad point drill or a small hole saw because there’s a fair chance that a regular twist drill will catch on the thin metal as it pierces through and rip it up making it necessary to open the wall to fix.
-- When the moderator chooses sides, his site sucks.
View chrisstef's profile
chrisstef
5204 posts in 1172 days
#2 posted 570 days ago
Garriv, im the commercial world they typicall install blocking within the cavity of the metals studs so they have something to attach to such as a sink, toilet, cabinets, etc.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View BentheViking's profile
BentheViking
1134 posts in 729 days
#3 posted 570 days ago
How heavy of things are the shelves and the contents? Generally they use self tapping screws to hold the sheetrock to the metal studs so maybe you could try that?
-- It's made of wood. Real sturdy.--Chubbs Peterson
View ShaneA's profile (online now)
ShaneA
3956 posts in 764 days
#4 posted 570 days ago
Are you using coarse sheet rock screws, or fine?
View crank49's profile
crank49
2276 posts in 1136 days
#5 posted 570 days ago
Drywall screws come in two types of threads.
Coarse threads are for attaching drywall to wood studs.
Fine threads are for attaching drywall to metal studs.
The same concept should apply to attaching anything to a wall stud system.
It’s best to use self drilling, fine thread screws.
For mounting to sheetrock (drywall) directly, light loads, I like self drilling anchors. They have very deep threads on the outside and regular internal screw threads with a screwdriver slot for installation.
Tap in plastic wall anchors work fairly well also.
For heavy loads on sheetrock walls with metal studs it’s best to use a cleat which spans several studs.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View DS's profile
DS
1816 posts in 586 days
#6 posted 570 days ago
I agree with chrisstef, any kind of wall load requires wood blocking installed inside the wall.
A base cabinet resting on the floor can be attached with drywall screws or anchors.
garriv777
#7 posted 219 days ago
Thanks guys, I appreciate the suggestions.
View Jim Finn's profile
Jim Finn
1062 posts in 1087 days
#8 posted 219 days ago
you can use long “drill tip” screws. They will go into metal very well. Instead of toggle bolts I would use the plastic, screw in, shields that you can then run a wood screw into.
-- In God We Trust
View huff's profile
huff
2549 posts in 1451 days
#9 posted 219 days ago
One thing to be careful of when using screws in metal studs, is don’t try to overtighten the screws. It takes a little feel to get used to using screws in metal studs. Over tighten and they will strip out very easily. Putting up sheetrock and having one strip out now and then is probably not a big problem, but hanging something heavy can cause a real problem. Having worked along the coast a number of years, most of the condo’s used metal studs in construction, so had to get used to working with metal studs. They can be a pain in the butt, but I really never had a problem with anything coming loose.
-- John @ http://www.thehuffordfurnituregroup.com
View Surfside's profile
Surfside
2277 posts in 339 days
#10 posted 219 days ago
How about using some washers?
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View waho6o9's profile
waho6o9
2878 posts in 742 days
#11 posted 219 days ago
View Loren's profile
4870 posts in 1813 days
#12 posted 219 days ago
You can get chisel point screws. They are hardened and black
like drywall screws but the points will pierce steel up to about
16 ga.
