Hardwood Floors Underlayment
Forum topic by Hermando posted 10-25-2011 12:56 AM 1580 views 0 times favorited 4 replies Add to Favorites Watch
View Hermando's profile
75 posts in 2732 days
10-25-2011 12:56 AM
Hello All,
I was hoping to get a good answer on a project I have upcoming. I have about 1500 square feet of solid pre-finished hardwood I am installing in my home. I have a question is using a standard Roofing Tar felt paper from the local building supply a safe product. Since it is a product that contains an asphalt chemical can it be used indoors without any toxic harm to the air quality. Or should I use a specific hardwood felt paper or Rosin paper from the flooring company.
I just want to make sure a I use the the right product since it will be a lifetime floor.
Thanks. H.
View Jorge G.'s profile
Jorge G.
1537 posts in 2410 days
#1 posted 10-25-2011 01:11 AM
You should not use tar paper, it will gas off and your house will stink forever. Use a foam backing, it is what I have used to install floors and what I am using now to remodel a house.
-- To surrender a dream leaves life as it is — and not as it could be.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3647 days
#2 posted 11-01-2011 04:28 AM
We’ve used the roofing felt as recommended by our hardwood vendor for our last two houses, haven’t smelled it since we installed it. As I recall it wasn’t very strong smelling when we put it in.
View newwoodbutcher's profile
732 posts in 2785 days
#3 posted 11-01-2011 08:53 AM
I used roofing felt under my cherry bedroom floor and haven’t noticed any smell at all.
-- Ken
View David Grimes's profile
David Grimes
2078 posts in 2574 days
#4 posted 11-01-2011 08:57 AM
Roofing felt. They have the synthetic now if you’re dead set against the tried and true.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
