Suggestion for Rabbet plane
« back to Hand Tools forum
Forum topic by Letorix posted 10-24-2011 05:35 PM 1305 views 0 times favorited 4 replies Add to Favorites Watch
View Letorix's profile
Letorix
119 posts in 2497 days
10-24-2011 05:35 PM
So many to pick from on Ebay, would like to spend less that $100.
Also I don’t know why they have what looks like two blades.
Thoughts, opinions, and experienced welcome and appreciated.
View cellophane's profile
cellophane
42 posts in 2502 days
#1 posted 10-24-2011 09:53 PM
Do you want a block plane or a larger plane? The multiple blade postions are usually a bullnose / rabbet plane or a fillester / rabbet plane. No real advantage to them that i know of over a regular rabbet except you have a single multi-purpose plane instead of needing two planes.
Here’s a Millers Falls Bullnose for less than $10
Stanley Duplex (doesn’t have a fence but does have a depth stop)
and a decent looking Stanley shoulder plane.
If you search by price I get 165 or so total auctions and have to go 3 pages back to get to planes over $100. The usual suspects all apply: Stanley, Millers Falls, Record, Sargent
For a little bit more you can buy the LN Rabbet for about $175 or a number of the Veritas planes.
Personally I would go for a shoulder plane over a regular rabbet plane but they tend to cost a bit more – I assume due to the extra metal in the body.
View Loren's profile
10373 posts in 3642 days
#2 posted 10-24-2011 11:37 PM
You are looking at the duplex models, which make a rough, but serviceable
cut. A skew rabbet plane like the Stanley 289 or new Veritas skew is
a much smoother cutting tool.
A Stanley no. 46 can serve as well.
Letorix
#3 posted 10-25-2011 04:12 AM
Ok, I’m thinking the biggest use would be for cabinets and tenons.
On the 78 duplex what is the front section used for?
I like the looks of the 289, the way the blade is at an angle.
Also like that 93 looks like you can use both sides.
These are good tips, Thanks!
View interpim's profile
interpim
1170 posts in 3452 days
#4 posted 10-25-2011 04:18 AM
I have a no. 78 I bought at an antique mall a while back… that front section is used the same way as the back area, but it lets you get closer to the end of a stopped rabbet
-- San Diego, CA
