Making a marking/cutting gauge cutter out of a hacksaw blade?
« back to Hand Tools forum
Forum topic by Brett posted 10-24-2011 04:42 PM 2687 views 2 times favorited 3 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2677 days
10-24-2011 04:42 PM
I’m almost finished cutting the wood for my marking/cutting gauges. Now I need to make a cutting blade.
I have an old hacksaw blade that I’ve snapped off to about the right length (in my metal vise), but I don’t know how to cut it to the right width, short of grinding all the excess metal off. Does anybody have any links to websites that discuss how to turn scrap bits of metal into cutting gauge irons, marking knives, etc?
-- More tools, fewer machines.
3 replies so far
View pierce85's profile
pierce85
508 posts in 2556 days
#1 posted 10-24-2011 05:52 PM
View mikema's profile
mikema
180 posts in 2580 days
#2 posted 10-24-2011 07:18 PM
Several months ago I made several marking knives. I ended up using a hack saw blade for my blades, but the process should be similar. The first thing I did was remove the teeth of the blade. I used my bench grinder. Make sure you hold the blade with something that is not your hands! After getting the teeth off, I ended up making several cuts using my dremel and a cut off wheel. The steel on these blades is harden, so other methods of cutting maybe difficult. Once I got the blade sized (usually with a small tang on it) I took it back to the grinder to shape the end of the blade on the bench grinder, again hold it with something other your hands. Next, using double sided tap, I attached the blade to a block of wood. I used this to flatten one side of the blade. Then flip it on the block and flatten the other side. (Use whatever method you prefer to flatten hand tools, the block of wood is for safety when using a machine, or to give you something to hold if doing it by hand)
Finally establish a bevel, again don’t use your hand to to hold the blade if using the bench grinder. Then sharpen that bevel with whatever sharpening methods you use/prefer.
-- Mike ---- Visit my woodworking blog: http://sawdustnewbie.com
View gfadvm's profile
gfadvm
14940 posts in 2684 days
#3 posted 10-25-2011 04:32 AM
Brett, I would forego the hacksaw plan and buy a #20 scalpel blade. It’s high carbon, SHARP, Has a slot to mount it, and can probably be had for free from your Dr. or veterinarian.
