What size cord?
Forum topic by D_Allen posted 10-23-2011 04:37 AM 977 views 0 times favorited 5 replies Add to Favorites Watch
View D_Allen's profile
495 posts in 2718 days
10-23-2011 04:37 AM
I want to replace the cord on an old sears motor that runs my jointer.
It is a 1/2 HP 1750 RPM and is rated at 6.7 amps.
I see that my 3/4HP lathe motor and the 1/3 HP DP motor both use 18-3.
The TS has a 14-3 but I’m not sure what HP, it is a BT3100.
So, I am thinking that at least a 14-3 cord. #18 seems too small.
I was thinking of getting a 14-3 heavy duty short extension cord and cutting off the end.
What say you guys?
-- Website is finally up and
5 replies so far
View Minorhero's profile
373 posts in 2539 days
#1 posted 10-23-2011 04:48 AM
Whenever re-making old machines I pretty much always replace the cords. I always use extension cords of either 14-3 or in the case of motors of 2hp or more 12-3.
View danr's profile
154 posts in 3119 days
#2 posted 10-23-2011 04:57 AM
14 gauge will be fine for the motor you describe.
Note that I am not a licensed electician (just had to say that).
I have done a lot of residential wiring (for myself) over the years and I have found that most local electicians are extremely helpful if you call them up with a question.
A cold 6-pack can also help in this regard.
#3 posted 10-23-2011 08:37 PM
I actually found that the local blue box had replacement cords for this purpose. No need to throw away the molded end. 14/3 SJTW 10 ft long.
View Grandpa's profile
3259 posts in 2610 days
#4 posted 10-24-2011 02:46 AM
I bought replacement cords with the plug molded on then found that if I watched for a sale I could buy the drop cords cheaper. I generally use 14 ga since it will carry about 15 amps in copper. Larger if you need more amps.
View HorizontalMike's profile
7749 posts in 2848 days
#5 posted 10-24-2011 03:57 AM
I believe that the premise is to have the power cord _”smaller”- than the 12-3 or 10-3 that is in your walls. This is because the power cord will burn up BEFORE the wiring in your wall.
That being said, I have been known to violate that premise when I put LONG power cords on equipment like my BS, TS, Jointer, etc. in order to give me greater portability in placement in the shop.
