Sharpening Help
« back to Hand Tools forum
Forum topic by CanalboatJim posted 10-23-2011 03:27 AM 931 views 0 times favorited 4 replies Add to Favorites Watch
View CanalboatJim's profile
CanalboatJim
200 posts in 3413 days
10-23-2011 03:27 AM
I just finished cleaning up a Stanley #82 scrapper. I used Evaporust on this project, and I have to say it worked just as well at the electrolysis method and was a whole lot easier. My question is what is the correct way to sharpen the blade? It does have a bevel already. Should it be truly sharp or just ground square? Should the blade have a burr? Any suggestions would be appreciated.
-- Jim Westbrooks
View David Kirtley's profile
David Kirtley
1286 posts in 2906 days
#1 posted 10-23-2011 04:03 AM
The thing is, the scraper planes have a much thicker iron and you use them more aggressively than you would a card scraper. You can put a bit of a burr on it but the scraper planes generally are just sharpened to an edge. A higher angle than you would use on a plane iron. I would go with about 35-40 degrees.
David Kirtley
#2 posted 10-23-2011 06:01 PM
The #80 is a bit nicer for that. As you tighten the screw, it bows the blade like you do with a hand scraper.
View RGtools's profile
RGtools
3372 posts in 2562 days
#3 posted 10-23-2011 06:11 PM
You mentioned evaporust. Is there any pitting on the back of the scraper blade, if so replace the blade? You will never get a scraper sharp if a pit runs through the edge. I file my blades a 45 degree angle, polish both the bevel and back with my finest stone, then use a carbide burnisher to form a small hook (you can feel it but not see it) on the blade. This hook does all the cutting.
-- Make furniture that lasts as long as the tree - Ryan
View Bill White's profile
Bill White
4861 posts in 3868 days
#4 posted 10-23-2011 07:44 PM
http://www.youtube.com/watch?v=Nz6EpQu2HRo
Look at this video from William Ng. Good info about cab scrapers.
Bill
-- bill@magraphics.us
