Wood prop for a boat?
Forum topic by thudpucker posted 10-23-2011 12:24 AM 4052 views 0 times favorited 20 replies Add to Favorites Watch
View thudpucker's profile
thudpucker
35 posts in 3540 days
10-23-2011 12:24 AM
Topic tags/keywords: humor
The Wright brothers first prop was Bent Wood. They had a Steam Bender and a Wind tunnel. The Wind tunnel was also made of Bent Wood.
Later on the props were laminated. Glued/laminated must have been the first choice till metal was in vogue.
I got to thinking of homemade stuff and wondered about a Wooden Prop for a boat.
The question is moot of course since metal is the best of all worlds, but if a prop of wood were on the menu, would it be Bent twisted, or would it be layers of wood, bonded and carved to shape.
Honestly, I’m not going to make one :) I’m just curious about what you guys think of it.
20 replies so far
thudpucker
#1 posted 10-23-2011 01:28 AM
LOL, yeah on Airboats. We had them in AK. Lot’s of funny stories there but I do not recall any on the Prop’s coming apart.
Naw, I was just interested in what anybody knew about Props for a boat.
Not paddle wheels etc, but spinning screws.
View JJohnston's profile
JJohnston
1622 posts in 3410 days
#2 posted 10-23-2011 02:21 AM
As fast as a boat prop spins, and as much resistance as water has, I would think it would wear out really fast. Ever see what rain (just rain) can do to a wooden airplane prop?
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View GaryK's profile
GaryK
10262 posts in 4107 days
#3 posted 10-23-2011 02:27 AM
You could laminate some blades that would work. Then just wrap the leading edges with brass sheet material. That would solve the wearing out problem.
BTW my grandfather used to make wooden propellers at Pratt and Whitney during WWI.
thudpucker
#4 posted 10-23-2011 06:43 AM
I’d think Cypress slabs laminated with wood dowells.
I wonder what the Paddle Wheelers used for wood?
They probably never gave Rot a passing thought and went right out for the Oak.
View BurtC's profile
BurtC
103 posts in 3249 days
#5 posted 10-24-2011 04:43 AM
I have a boat and I wouldn’t even think of using a wooden prop. RPM can hit 3K easily. Even the cheap powder coated cast aluminum props do not last long. Best available is stainless. And when that wooden prop breaks, it’s a long row home…
View SnowyRiver's profile
SnowyRiver
51457 posts in 3599 days
#6 posted 10-24-2011 03:02 PM
I agree that I dont think a wooden prop would last long on a boat….especially if it has some horsepower. I have a 250 hp engine on mine and I cant imagine it lasting more than a couple of blocks across the lake. My prop is stainless and I know it takes a beating.
-- Wayne - Plymouth MN
thudpucker
#7 posted 10-25-2011 01:13 AM
You guys are completely correct. Any Wood prop would be a Slow speed, low leverage device.
I just had the thought when I saw a Wood Prop of laminates, and the Airplane prop’s of both Laminates and carved/Bent of a single piece of wood.
I’d sure be careful if I had a wooden prop!
I think I’ve learned all I need to know about wooden props. Maybe I’ll make a small boat with an enclosed Paddle wheel? :)
View Kayinde's profile
Kayinde
3 posts in 2147 days
#8 posted 11-06-2012 02:52 AM
Hurricane sandy gifted me with what I believe is an antique wooden boat prop about three feet in diameter with four blades. Does not look like an airplane prop at all and had pitched blades similar to a metal prop. Having a heck of a time researching it
Craftsman on the lake
2804 posts in 3557 days
#9 posted 11-06-2012 02:55 AM
The edges would round after a short while then it would get smaller and smaller from wear.
JJohnston
#10 posted 11-06-2012 03:31 AM
Would love to see some pictures of that, Kayinde.
thudpucker
#11 posted 11-06-2012 05:33 AM
IF the Wood props wear, how about the Aircraft wood props? Dont they wear?
Maybe you’d need some stainless on the leading edge of the blade?
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2229 days
#12 posted 11-06-2012 12:59 PM
All airplane propellers wear, even metal examples. Props have their own maintenance logs, separate from the engine and airframe, and a set of inspection and maintenance requirements. It’s surprising how much wear an aluminum prop gets flying through rain.
As far as I know, the reason propellers moved to metal was more about ease of manufacturing and repairing a more consistent and predictable raw material, as well as overall weather resistance. Most airplanes with wooden props or other parts, have to be stored indoors.
Anytime a rotating aircraft propeller makes contact with anything stationary, all kinds of inspections to the engine and prop are required. I would imagine that wood, a natural fibrous product, would be capable of hiding internal damage and stresses, too. This would make it subject to unpredictable failure.
JJohnston
#13 posted 11-06-2012 01:14 PM
I had a flying instructor tell me that wood propellers are always to be left horizontal when the airplane is parked, so if there is any water in it, it won’t be pulled by gravity toward the tip pointing down and throw off the balance. Then again, this instructor stubbornly refused to use a headseat, claiming you could hear detonation better without one. I never did hear a word he said while the engine was running.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3704 days
#14 posted 11-06-2012 02:19 PM
wooden prop fine untill your prop hits a stone or mud etc then it will disintegrate.The reaction with water is not a problem as I see it look at paddle steamers all wooden props of a kind .Alistair
Kayinde
#15 posted 11-06-2012 03:26 PM
Here is the prop in question. Does it look like a boat prop to you?
