Delta 6" pro jointer seeking new home
Forum topic by WordCooper posted 10-22-2011 11:33 PM 9967 views 0 times favorited 0 replies Add to Favorites Watch
View WordCooper's profile
3 posts in 2340 days
10-22-2011 11:33 PM
Topic tags/keywords: jointer delta professional 37-195
Delta 6” professional jointer needs a new home near Vancouver, Washington.
I bought this Model 37-196 (37-196 was Delta’s re-labeling of 37-195 jointers returned for factory reconditioning) in 2002.
It’s been lightly used (maybe 10 hours) and is in great shape; both infeed and outfeed tables are flat and true. I wax the tables and fence regularly.
It’s on a Shop Fox mobile base.
I’m downsizing and can’t justify the space for this machine takes for the times I use it. I’m hoping some other woodworker can use this great machine.
$325, you pick up.
Here are the details:
Rack and pinion fence adjustment for precise fence movement.
Large cast iron infeed and outfeed tables support extra long stock.
1 HP motor wired for 110 current.
The enclosed steel stand includes an integral dust connector with 4” diameter outlet.
Conveniently-positioned on/off paddle switch is placed high above the table, in full operator view, for quick access.
Safety cutterhead guard pivots out of the way during operation.
Extra-large, center-mounted cast iron fence provides maximum work support throughout the cut.
Quick-index infeed table positioning lever for fast, accurate set-up
Motor – 1 HP, 115/230V, single phase, 60 Hz, 1725 rpm
Speed – 4800 rpm, 14,400 cpm
Number of knives – 3
Diameter – 2-1/2 (64 mm)
Width – 6-1/8” (156 mm)
Depth – 1/2” (13 mm max.)
Rabbeting – 1/2” x 6” (13×152 mm)
Length – 46” (1168 mm)
Length of Rear Table – 22-1/2” (562 mm)
Length of Front Table – 22” (559 mm)
Size – 3-3/4” x 24” (95×610 mm)
Tilts in and out – 45 deg. right and left
Positive Stops – 90 deg., 45 deg. right and left
Width – 46” (1168 mm)
Depth – 28-1/2” (724 mm)
Height – 48-1/2” (1232 mm)
Weight – 225 lbs. (102 kg)
Woodcooper in Battle Ground
0 replies so far
