router bits.. and lowes..
Forum topic by joshtank posted 10-22-2011 08:12 PM 5090 views 0 times favorited 24 replies Add to Favorites Watch
View joshtank's profile
224 posts in 2906 days
10-22-2011 08:12 PM
I don’t have a professional shop by any means, just hobby stuff here and there. I recently got a $100 gift card to lowes. and since i just got my first router table set up, i was thinking on getting some router bits. (the ones i have now are old craftsman from my grandfather, mostly just steal, no carbide, very easy to leave burn marks.)
i hear everyone talking about whiteside and even the cheaper woodcraft brand. BUT being a librarian by day and having a new addition to the family staying at a certain lower price range is nice. and with the gift card, staying at LOWES is nicer..
so.. Bosch bits? are they total crap?
Skil bits? am i just asking to lose an eye?
I saw other posts about bits, but none of them were sold at lowes.
lowes also has CMT bits, which means i can get.. maybe two bits for $100.
is anything else at lowes such a good deal i should just keep the card for that? finishes etc..?
-- Josh - Jacksonville, FL -
24 replies so far
View Don's profile
517 posts in 3006 days
#1 posted 10-22-2011 08:26 PM
Bosch and woodcraft bits are fine. Higher end bits will cut cleaner and stay sharp longer but for me that’s not always worth the higher cost. For things like roundovers I generally buy cheaper bits because it’s easy to sand. For things like raised panel sets and ogees I buy high end bits because those profiles are much harder to sand.
-- Don - I wood work if I could. Redmond WA.
View Bill White's profile
Bill White
4878 posts in 3893 days
#2 posted 10-22-2011 08:50 PM
Don’t rule out Grizzly for value in bits. Look ‘em up, it’ll be worth your while.
I don’t suggest you buy sets. Just buy what you want/need. There will be a lot of duplication in sets.
CMT bits are good, and Rockler often offers deals. Bosch bits are good, just pricey at a Borg.
View richgreer's profile
4541 posts in 3007 days
#3 posted 10-22-2011 10:47 PM
At the Lowes near me, almost all the router bits have a 1/4” shank. I really try to avoid 1/4” shank bits. They break too easily.
As Don says, Bosch and Woodcraft bits are okay, but stay away from the 1/4” shank.
If it were me, I would use the gift certificate for the disposable items you are always using up (e.g. sandpaper) and/or their Kobalt line. In general, I think the Kobalt brand is pretty good stuff at a reasonable price.
View knotscott's profile
7937 posts in 3308 days
#4 posted 10-23-2011 01:16 AM
Bosch bits are pretty good though usually too expensive to bother with, but I’m definitely skeptical about the Skil bits. One possibility is to sell your Lowe’s card and use the cash towards bits that make the most sense without being limited to Lowes.
The basic 7 pc Whiteside set of the most commonly used profiles is ~ $80 shipped…top shelf American made cutters. The 15 pc MLCS set is $40 shipped, and are decent import bits. I would not buy a large set because the total cash outlay is still high, and you end up with a bunch of cheap near duplicate bits. Get 1/2” shank whenever feasible, assuming your router accepts 1/2” shank.
View Jacob Lucas's profile
Jacob Lucas
100 posts in 2365 days
#5 posted 10-23-2011 01:26 AM
One thing to watch out for is if you are gonna be using them in a trim router, be sure the shank size is right. Most trim routers only accept a 1/4 inch shank. Personally I do most of my routing with a trim router, its just easier for me.
View David Kirtley's profile
David Kirtley
1286 posts in 2931 days
#6 posted 10-23-2011 03:56 AM
I would say get one of the $100 30 piece sets of the Skil bits.
The rationale:
The bit difference between cheap bits and high quality bits is really the grade of carbide. The Skill bits are not bad bits, they are just not GREAT bits. There are a lot of profiles you won’t use often. Having them is nice to pull out once in a while. For occasional use, they are fine. As you replace them, replace the ones you use often with high quality bits. They will last and stay sharp longer.
I have a mix of bits myself. Some are the bargain bin from Harbor Freight. Some are pricey. Some outright painful to buy. If I am just going to use one for one piece, I get a cheap one. If I intend to use it often, I go ahead and get a good one.
-- Woodworking shouldn't cost a fortune:
View DamnYankee's profile
3301 posts in 2495 days
#7 posted 10-23-2011 05:00 AM
What David said. I got similar advice when I first started. I also got told (and mostly followed) was to keep track of the bits you use and how often you use a bit by making a pencil mark on the shaft when the shaft is all marked up go by a high quality bit of that profile as you know it will be worth it. If you are like most you will buy a straight bit, an ogee a round over and a trim bit
-- Shameless - Winner of two Stumpy Nubs Awards
View RibsBrisket4me's profile
1555 posts in 2438 days
#8 posted 10-23-2011 05:52 AM
I bought a 50 bit set for $50 from a now defunct company called Blade-N-Bits. They are okay and prolly in line with Skill bits. Over the years I wait for the Woodcraft $5 sale and stock up on my most used profiles. I’ve looked at the Bosch bits in Lowes, but never used them. I think they look fine and I would buy one in a pinch.
The Whiteside 7pc set is a nice way to go too.
View grantlairdjr's profile
31 posts in 2523 days
#9 posted 10-26-2011 01:51 PM
Try Harbor Freight Tools store…
-- Grant Laird Jr - Garland, Texas
4906 posts in 2426 days
#10 posted 10-26-2011 06:21 PM
I’ve never used Skil bits, but I have tried a couple of Bosch and thought they were pretty good. I might not rate them with Whiteside, but higher probably than MLCS. Remember, Bosch now owns Freud bits/blades (since ‘08)...they have some knowledge on this stuff somewhere in the corporate archives. BTW, I’ve also used quite a few of the Woodcraft bits, bought mostly when they have the $5/ea. sale. They are actually quite good, though again, I wouldn’t rate them with a Whiteside. But when you can buy 3-4 other bits for the price of one Whiteside what can you lose?
View Guss's profile
94 posts in 2374 days
#11 posted 10-27-2011 03:40 AM
I really like wood line usa bits and there on the lower side of the router bits cut really clean. i have used some woodcraft bits there not to bad. I would not go for the harbor freight bits I have a set of 4 i picked up and they dont cut near as nice as any of the other bits that i have
View Rxmpo's profile
268 posts in 3678 days
#12 posted 10-27-2011 04:04 AM
Saw a great review from another jock harrywho about this site so I ordered a dovetail bit for my Leigh jig and I was very happy with the product, speed of delivery, and price. Not only that, the owner Alan personally sends emails and responds. Even followed up with an email a few weeks after to make sure all was well. I won’t buy a bit from anywhere else now.
CR1 just had a great experience as well. If you are looking for bits this is the site to go with IMHO.
View Roger Clark aka Rex's profile
Roger Clark aka Rex
6940 posts in 3367 days
#13 posted 10-27-2011 04:28 AM
I have quite a few router bits, some are mid range for occasional needs and the rest are higher end bits. MLCS bits are good and fulfill the need for bits you don’t have any punishing daily long term usage. Bosch are good, as are Freud and Milwaukee (Freud’s). Whiteside are very good heavy duty bits. Amana, for me are the Rolls Royce of router bits, superb long lasting heavy duty precision bits – the best.
HF bits, I wouldn’t touch with a 10’ pole.
Probably the best deal around is Milwaukee, as they are the very same Freud bits with a different logo, made by Freud, and are cheaper than Freud.
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
#14 posted 10-27-2011 05:03 AM
Roger – I’d almost forgotten that Freud made several of the Milwaukee bits. About a year ago I bought a 3-1/2” horizontal panel raiser that has the Freud 2+2 “quadra cut” technology for $10 from Amazon! Haven’t tried it yet, but it was a whole lot cheaper than the red one!
View spamfilterman's profile
149 posts in 2955 days
#15 posted 10-27-2011 05:21 AM
Me too with picking up the Milwaukee/Freud bits when they were on heavy sale at Amazon… I think I got that same panel raiser, and a few other high quality bits. I with I would’ve picked up more.
