cedar chest
Forum topic by cebfish posted 10-22-2011 03:27 AM 1205 views 0 times favorited 2 replies Add to Favorites Watch
View cebfish's profile
cebfish
156 posts in 2715 days
10-22-2011 03:27 AM
I built a cedar chest. I wanted to know if I should use sanding sealer before poly or what about using linseed oil before poly
2 replies so far
117120 posts in 3604 days
#1 posted 10-22-2011 03:49 AM
I would not put a finish on the inside and if you want something to help the poly bond put a couple coats of 1lb cut of wax free shellac on before your poly. I would never use linseed oil it can take months for if to dry.
View Bill White's profile (online now)
Bill White
4949 posts in 3987 days
#2 posted 10-23-2011 08:22 PM
Zinsser Seal Coat on the exterior. Why do ya want to use polycrapithane? A good wiping varnish will work well. Several coats after the shellac. Let the varnish cure properly, wax and steel wool (0000), then buff. You’ll have a treasure without the plastic look.
BTW, I only use a urethane for hard use areas such as table tops and floors. It has its place, but, IMHO, not on furniture such as a chest.
Bill
-- bill@magraphics.us
