thinning polyurethane
Forum topic by Jeff Murdock posted 10-22-2011 03:26 AM 10454 views 1 time favorited 4 replies Add to Favorites Watch
View Jeff Murdock's profile
Jeff Murdock
3 posts in 2334 days
10-22-2011 03:26 AM
Topic tags/keywords: resource
It has been suggested to thin or cut Minwax polyurethane so it will go on easier. How much should I cut it and with what? Mineral spirits or paint thinner?
-- Jeff, McDonough, GA
View gfadvm's profile
gfadvm
14940 posts in 2591 days
#1 posted 10-22-2011 04:14 AM
I use 1 part mineral spirits to 3 to 4 parts poly (I also really like this mix to wipe on Spar urethane as it has a less ‘plastic’ look to me).
4868 posts in 2395 days
#2 posted 10-22-2011 01:55 PM
Paint thinner should be cheaper, but they both do the same thing for thinning.
View nailbanger2's profile
nailbanger2
1041 posts in 3045 days
#3 posted 10-22-2011 02:44 PM
The main ingredient in paint thinner is mineral spirits. A half and half mixture will give you wipe on poly. Dries in two hours, but you’ll need more coats.
-- Wish I were Norm's Nephew
View Fuzzy's profile
Fuzzy
297 posts in 3890 days
#4 posted 10-23-2011 04:25 AM
I don’t use Minwax if I can help it, but I use VM&P Naptha to thin poly and Waterlox, and the first several coats I use about 70-75% Naptha to 25-30% finish. It drastically reduces surface tension and allows the finish to seep deep into the pores of the wood.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
