Disston and Warranted Superior
« back to Hand Tools forum
Forum topic by Luke posted 578 days ago 1419 views 0 times favorited 5 replies Add to Favorites Watch
View Luke's profile
Luke
450 posts in 1463 days
578 days ago
Topic tags/keywords: hand saw disston
I got these two saws at a yard sale and wanted to see if anyone knew anything about them. The one with the thumb hole is a Disston D-6 two hander and the other is a Warranted Superior 8. Both are 26” long blades and have pretty heavy rust. The teeth are also really dull. They won’t even cut pine easily. Is it a bad idea to clean them up and use them? Are they antiques that shouldn’t be touched? I just don’t know much of anything but they looked like good saws so I picked them up.
-- LAS, http://www.abettersign.com
5 replies so far
View cellophane's profile
cellophane
42 posts in 677 days
#1 posted 578 days ago
Sharpen those bad boys up and cut away! I believe the Disston is a D-8. Skimming through the Disstonian site I didn’t see a D-6. Either way it will be a great saw.
I would try to date the Disston just to verify it isn’t something super old – otherwise I don’t think it is worth not using it. You can use the medallion for dating
http://www.disstonianinstitute.com/
http://www.disstonianinstitute.com/medv2.html
View ksSlim's profile
ksSlim
802 posts in 1059 days
#2 posted 578 days ago
Warranted Superior is/was Diston’s “economy” brand.
-- Sawdust and shavings are therapeutic
View Don W's profile
Don W
9952 posts in 737 days
#3 posted 578 days ago
I agree. They were made to cut. CUT.
View Brandon's profile
Brandon
3753 posts in 1120 days
#4 posted 578 days ago
Luke, check out this link for cleaning those bad boys up:
http://www.vintagesaws.com/cgi-bin/frameset.cgi?left=main&right=/library/library.html
Also, you suck for scoring those at a garage sale. I only say that because it probably wasn’t far from my house. :-)
-- "hold fast to that which is good"
View Luke's profile
Luke
#5 posted 578 days ago
Well then I won’t tell you how much they cost Brandon cause you’ll really cry then. Thanks for the info. I’m still trying to figure out if they are old or not. It’s much harder than I thought it would be. Not a whole lot of info and they don’t quite fit the ones that I have seen on the web.
