Non-Stick Blade Coating Becoming More Popular
Forum topic by motaro38 posted 10-21-2011 04:25 PM 1028 views 0 times favorited 0 replies Add to Favorites Watch
View motaro38's profile
motaro38
1 post in 2436 days
10-21-2011 04:25 PM
First post figured I’d try to add some insight. The Freud’s coatings aren’t paint, they’re aluminum based and drastically reduce the amount of heat created, which can destroy a blade via warping or dull it more quickly by overheating the carbide. This is more important in ripping. The coating also reduces pitch/gum build up, which as we all know is annoying and messy. When I first used the Diablo blades with this coating, I was amazed at how smoothly the blade went through the wood, with very little effort required on my part. Then again, I was used to run of the mill throwaway construction blades from DeWalt, Black & Decker, Makita, etc., so it could of course have been the general lack of quality of what I was used to.
It seems other brands are now coating some of their blades with what appears to be the same thing.
Freud permaSHIELD
DeWalt Tough Coat
Makita ULTRA-COATED
Amana Tool ARMORMAX
Skil
This blade is included with their newer worm drives.
Bosch
CMT TeflonĀ® industrial coating
Ridgid – T3 Titanium Coating
Irwin only has one blade with a coating. It’s a deck blade designed for cutting PT. Product description states it’s a silicone coat. If you look closely you can see the brushed steel under the coating, which cannot be seen in the Makita or DeWalt blades. The aforementioned two seem to carry a coating more similar to the Freud.
There’s obviously some differences among the coatings. Freud uses an aluminum alloy, CMT uses Teflon, Irwin’s coating is just a thin layer of silicone, and the other brands are anyone’s guess. I’m not sure which brand first started applying these coatings, but Diablos were the first I saw them on. Regardless, I’m thankful they’re becoming more prominent, and I hope all blade manufacturers begin using them on all their blades.
0 replies so far
