| Forum topic by jasoncarpentry | posted 607 days ago | 1567 views | 0 times favorited | 7 replies | ![]() |
607 days ago |
A few months ago, I asked for input on a 22” x 18” cutting board that was warping. After a few attempts, I’ve sorta fixed this one, but now I have a request for another, and I want to get it right from the begining. I’m using 3/4” thick x 1 1/4” wide pieces, alternating maple and cherry. For the first one, I used no internal stiffeners (I’ll explain below) and Titebond II glue. I’ve seen plans where the pieces were “threaded” onto two pieces of 1/2” or 3/4” dowels. This helps w/ alignment during glue-up, and supposedly helps prevent the board from warping. For my new board, I plan to use polyurethane (Gorilla) glue and, instead of wooden dowels, I’m considering steel rods or steel all-thread. These would be either 1/2” or 3/8”, and the end slats would have blind holes to cover the ends of the steel rods. What do you think? Is there a possibility of rust, even though the rods will be encased within the board? If that’s a possibility, I can epoxy-paint the rods before assembly. This is sometimes done w/ rebar in certain concrete pads. -- Jim in Tennessee |
7 replies so far
#1 posted 607 days ago |
That’s not a big cutting board by any means… Wrong approach. The dowels don’t prevent warping and even worse is to use threaded rod. Wood expands and contracts so the rods restrict movement and create other stresses. Don’t even compare concrete and rebar with wood and threaded rod. The big butcher block top companies do it the right way… You original problem is from the wood wasn’t all dried the same. -- Few folks really know how to maximize the potential of their tools! |
#2 posted 607 days ago |
Rick- -- Jim in Tennessee |
#3 posted 606 days ago |
#4 posted 606 days ago |
Gorilla glue isn’t going to prevent warping. Gorilla glue isn’t the best polyurethane glue on the market anyway. Jowat and others make a better less foaming glue. Keeping the top surface wet would cause warping. What are you applying to the surface? The site I listed tells more than you realize. They use radio frequency gluing to speed up the process. You should read their recommended maintenance. They also talked about flipping cutting boards over so you need to rethink your project. -- Few folks really know how to maximize the potential of their tools! |
#5 posted 606 days ago |
Which way is it warping? up/down or side-to-side? I’m also wondering about the wood choice: Maple is very tight grained and does not absorb moisture quickly. I think cherry is much more absorbent. (I’ve never made a cutting board – so maybe that’s a common combination and works for others?) So how are you sealing this – to prevent moisture absorbtion which would cause uneven swelling? What about grain orientation? All grain vertical? A look at Rick’s link – they use 100% maple and I saw a comment that they always use vertical grain. (what they call “chopping blocks” are end grain) 1. a urethane glue will not weaken when wet -- Some problems are best solved with an optimistic approach. Optimism shines a light on alternatives that are otherwise not visible. |
#6 posted 602 days ago |
A cutting board needs to stand up to how it will be used. Cutting boards are subjected to moisture, heat and sometimes in ways they were not intended. I think 3/4” is pretty thin for a sturdy board. Rick I has it right. Butcher block construction uses end grain as the working surface. If you use it for chopping, end grain is the only way to go. For cutting and slicing, I would still go with the end grain block or plastic. Those alternating wood boards may look nice, but they weren’t designed to stand up to heavy duty use. I would treat them as decorative and maybe use them for slicing and serving cheese. To keep one of those boards from warping, never wash it, but only wipe it down with a damp cloth and dry it. This precludes you from using it for cutting, slicing or chopping meats, poultry, fish or vegetables. Once the surface is breached through knife cuts, the woods will be subject to warping. |
#7 posted 600 days ago |
I realize that posts come and go so fast here that the responders may never see this, but … As always, thanks for your comments & questions. I’ll attempt to answer them here: 1. MrRon: I misled you on the board’s thickness. It’s not 3/4”; it’s more like 1-1/4”. 3/4” was the thickness of the individual pieces before I turned them on edge and did the glue-up. But the site that RickL linked to sells boards w/ minimum thicknesses of 1-3/4”, and some are as thick as 3”. IMHO, the thicker the board, the less likely it is to warp. -- Jim in Tennessee |
| Forum | Topics |
Woodworking Skill Share
8848 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15984 |
Hand Tools
2101 |
Jigs & Fixtures
501 |
Wood & Lumber
2909 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6134 |
